Help - Need ATS Twin Carbon - Where to get ?
Old Nov 23, 2004 | 01:08 PM
G3po's Avatar
G3po
Default Re: Re: clutch
Originally posted by Enron Exec
Thats another 500 bones though , plus my shop already ordered mine.
Have you ever gotten the chance to drive one?
Old Nov 23, 2004 | 01:36 PM
dansouliere's Avatar
dansouliere
What would be the best flywheel to match up the 1100kg ATS triple soft?
Old Nov 23, 2004 | 01:40 PM
G3po's Avatar
G3po
Default ATS
It comes with an integral Flywheel already. This is pretty much the norm for dub and triple carbon clutches.
Old Nov 23, 2004 | 03:30 PM
Enron Exec's Avatar
Enron Exec
Default Re: Re: Re: clutch
No but if you do a search for "ATS" you will see at least 3 board memebers that have this clutch. Ive PMed 2 of them and according to all their testimonies, they still love it for being a soft and easy performance clutch.
If everything goes smooth, i'll be breaking in the clutch and motor on 1 psi of boost in 3 weeks.
Old Nov 23, 2004 | 04:02 PM
G3po's Avatar
G3po
Default Re: Re: Re: Re: clutch
Cool , awaiting your feedback.
I've got some time , I'm not installing till early 2005.
Old Nov 23, 2004 | 04:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I am definately setting up a GB on these...stay tuned.
Old Nov 23, 2004 | 04:13 PM
G3po's Avatar
G3po
If the price is right , I might bite.
Sounds like the most prevalent choice so far is the 1350kg , twin.
Seems like the extra cost of the triple turns some off.
Old Nov 23, 2004 | 04:57 PM
Sharif@Forged
Forged Performance
I agree...we can probably do any combination of discs and plates.
G3, what would be the drawback of going with the triple carbon discs, but the lighter pressure plate?
Old Nov 23, 2004 | 06:39 PM
Ellas1's Avatar
Ellas1
GQ- I went with the triple carbon and the lighter plate because it's easier to slip the clutch for normal driving.. Yasou the guy at ATS will work out a great price for you guys with multiple buyers... He took care of me because I was one of the first to have it....
Old Nov 24, 2004 | 10:08 AM
G3po's Avatar
G3po
Default ATS
That's news to me , I thought they only offered a basic Fywhel and a "heavier" one. I'd definately go with a lighter fly and triple "soft" @ 1100kg if given the choice. Given the ability to slip more easily would seem to offset the "easy to stall " properties of a lighter fly. Grabby clutches (ie. pucks, Cera-metalic and the like) and light flywheels in combination to be very street conducive.
My ultimate goal is for a long lasting as OEM-like as possible clutch and fly that wieghs the least and can relaibly holld 800crank.
Basically if I turn down my boost , and my wife drives the car , she wouldn't notice a diff over stock.
Old Nov 24, 2004 | 10:10 AM
G3po's Avatar
G3po
Default triple carbon
So Ellas did you also go with the "soft" type carbon and the 1100kg clamp?
How much rattle and chatter is there?
Old Nov 24, 2004 | 04:24 PM
Sharif@Forged
Forged Performance
I think this is the route that I will go. Triple carbon disc, and ligher 1100kg pressure plate.
Just as an FYI, this entire assembly, including the flywheel, is roughly half the weight of stock. Amazing.
Old Nov 24, 2004 | 06:02 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Call me stupid, but how much is this stuff?
Old Nov 24, 2004 | 06:58 PM
joenismo's Avatar
joenismo
I already have the tilton dual cera metallic setup and was considering switching to the dual carbon/carbon setup. Jason at Performance said that with a triple carbon that you would have to adjust the clutch every so often. Is that true with any dual and triple clutches or just the tilton?
Old Nov 24, 2004 | 11:00 PM
G3po's Avatar
G3po
Default adjustment
No the adjustment proceedure (a PITA) for the Tilton is specific to an "ultra light carbon rally clutch of it's type. The ATS and RPS carbons don't require adjustment beyond the main install and break-in, similar to most other generic clutches. I have explicitly asked both companies about this point.
Old Nov 24, 2004 | 11:05 PM
G3po's Avatar
G3po
Default cost
see GB thread:
https://my350z.com/forum/showthread....hreadid=100141
Old Nov 25, 2004 | 01:23 PM
Ellas1's Avatar
Ellas1
G3- I did get the 1100kg I felt the 1350kg and it is very stiff so I didn't like it for normal driving...
I'm not going to lie guys there is alot of chatter when the cars at idle that's the only thing I don't like about the clutch but It's a small price to pay for the horsepower we're all going after and a street clutch that feels like stock to handle it!!!
Old Nov 25, 2004 | 05:46 PM
  #38
Sharif@Forged
Forged Performance
Yup...I forget to mention that as well. By "stock engagement and feel:, I am refering to the feel of the clutch pedal, and the way the lutch engages and disenges under power.
But you are correct, the clutch will make some noise at idle...becuase the carbon discs are mounted on floating hubs. This noises are definately a minor drawback, when you consider the fel and power of the clutch.
Old Nov 25, 2004 | 08:01 PM
  #39
G3po's Avatar
G3po
Default ATS
Thanx , in addtiona ot the 1100kg option did you get the standard disks or the special "soft version"??.
The "std" disks are good to 1200bhp
and the "soft" disks are reduced to 800bhp.
I was told by ATS that the new "soft type" is even smoother and makes less "chatter", even more civil for street use..
800bhp is the most many of us (even with built long blocks) could ever intend to see.
Thanx
Old Nov 25, 2004 | 08:28 PM
  #40
dansouliere
The triple 1100kg "soft type" is definately the ultimate setup!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
