R4 Software Help needed...
Old Nov 22, 2004 | 10:22 AM
zbicklin's Avatar
zbicklin
Default R4 Software Help needed...
I just ordered Split Second's R4 software today. I want to lean things up a little more as I am currently running mid to low 10's A/F over 4 psi boost. In some spots over 7 psi I've seen 9.9 A/F.
I've read a bunch of threads regarding the R4 tuning so I feel I have a good base of knowledge to start with, but I did have a couple questions.
1. Once you establish connection with the SS box, can you immediatley save the current settings as a baseline?
2. Can anyone out there experienced with R4 tuning email me their Fuel and timing maps? I am looking to for low to mid 11:1 A/f after 4 psi.
If anyone out there can please help I would really appreciate it.
Thanks,
Steve
Old Nov 22, 2004 | 11:10 AM
chops's Avatar
chops
You really need to find someone that has experience with the R4 and start with your own base map. I tried a couple of maps that were emailed to me and the a/f went way lean on me.
My tuner has a ton of experience and it took him about 2.5 hours to get me in the 11's across the board.
I got files out the ying yang if you want them, but I don't recommend it.
Old Nov 22, 2004 | 11:18 AM
zbicklin's Avatar
zbicklin
Thanks... I had my car tuned at a Altered Atmosphere already and had their F/I ecu reflash. They could have done more tuning, but I was there all day and di like 30 pulls just to get where I was at. I also don't feel like driving 50 miles and paying $$ to lean things up a bit.
I would like to learn the R4 and become comfortable with it before I do any actual uploading to my car. My email is sbicklin@aerotek.com if you could email me.
Thanks for your help and advice.
Steve
Old Nov 22, 2004 | 01:44 PM
dfw350z's Avatar
dfw350z
Steve [/B]
I agree - be careful what you change. You can view my maps if you like online. They are linked on my web page.
Old Nov 22, 2004 | 05:17 PM
freezeg35's Avatar
freezeg35
dfw, am i reading your maps wrong or are you pulling 2.2 degrees of timing at 8 psi 2.4 at 8.5 etc. If so whats holding that thing together?
Old Nov 22, 2004 | 05:45 PM
booger's Avatar
booger
Freezeg35...dont try to run that less of timing retard . I tried and broke a piston . All of Grubbs Infinity's that John tunes , have less timing pulled than shoulds be . Im not sure how he is doing it . I believe he is using a knock sensor when he tunes . Be careful
Old Nov 22, 2004 | 05:57 PM
dfw350z's Avatar
dfw350z
I agree be careful, apparently they tune freak cars that seem to work. I have 8k+miles on my car without a problem.
Perhaps I should refrain from posting about timing issue..
Old Nov 23, 2004 | 04:00 AM
zbicklin's Avatar
zbicklin
Thanks DFW350z... I guess my whole point is to be careful. I only wanted to touch the fuel maps and nothing else.
Does anyone know if I can download my base map I currently have on the car with out affecting the settings? I want to look at it, make sense of it, and then slowly try to lean things up a little.
I really appreciate everyone's cautious advice, but I've been tuning cars for a long time and have already made every dumb mistake in the book. I don't plan to do that with my Z.
I need everyone's help so I can get familiar with how R4 works and the processes before I make any changes to my current maps.
Thanks Everyone!
Old Nov 23, 2004 | 06:17 AM
enthuzd's Avatar
enthuzd
You should be able to create a new customer, title it base or backup or whatever you want, hit connect to ECU, open the maps page, download from car...
Old Nov 23, 2004 | 10:33 AM
zbicklin's Avatar
zbicklin
Thanks enthuzed! One last question for anyone that can answer... The numbers in the fuel map matrix represtent the amount of fuel added to each rpm/boost point correct? I read that the higher the # the more fuel at those points the lower the # the less fuel... Is that correct?
So my plan is to slowly lower the numbers from my base fuel map, save each new map as a different name and hopefully things will lean out to the mid 11's. Correct???
Old Nov 23, 2004 | 12:39 PM
booger's Avatar
booger
Yes that will work .Also make sure to check your system settings and output settings are right before you write to ECU .
Old Nov 24, 2004 | 02:39 PM
CaneZMD's Avatar
CaneZMD
r4 is very easy. Just get a datalogging AF gauge and you can tune by doing 2nd gear pulls on any street by your house. That's what I did.
I also used booger's charts as a guide. Although, when I looked at booger's timing map I thought. "That's not much timing retard" so I left it alone. (Not that I'm a tuning expert or anything) I'm glad that I left it alone now.
Booger, can't wait to see how your engine build ends up.
Old Nov 24, 2004 | 03:15 PM
booger's Avatar
booger
Should be in the next 3 weeks
Alang
Jul 29, 2003 11:18 AM
Quick
Jul 16, 2003 04:33 AM
DBZ33
May 14, 2003 10:55 AM
Scafremon
Apr 15, 2003 05:17 AM
