engine break down begins
Old Nov 22, 2004 | 02:49 PM
booger's Avatar
booger
Default engine break down begins
I stopped at the shop today and Bob has my heads off . Middle cyl. on the drivers side broke a bigger piece off than I thought . Exhaust valve is bent , so it needs to go out and be checked out and replaced . We found the piece in the cat . All the cyl . looked like they are getting enough fuel . The cyl. that broke , you could see some detonation marks on it . It wasnt as dark as the others because of being washed with unburnt fuel . The pics are crap....cheap little camera and if you dont hold it perfectly still , its blurry
Old Nov 22, 2004 | 02:52 PM
booger's Avatar
booger
Default pass side cyl.
passenger side
Old Nov 23, 2004 | 03:25 AM
booger's Avatar
booger
Just thinking...Should I replace the head bolts when the shop puts back on the heads ? any one know ?
Old Nov 23, 2004 | 04:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Im pretty sure the head bolts on the Z are "stretch" bolts, meaning when they are torque'd to spec they stretch some. If this is the case, then you should get some new head bolts. Someone please correct me if I'm wrong.....
Old Nov 23, 2004 | 08:45 AM
booger's Avatar
booger
Ordered the head bolts today . Heads got taken to machine shop to get checked out and install new valve springs .I will have to order a valve or 2 also
Old Nov 23, 2004 | 10:02 AM
arizzee's Avatar
arizzee
Just checked the service manual and it doesn't show the head bolts as replacment items upon reassembly. But it won't hurt to replace them.
Old Nov 23, 2004 | 12:09 PM
booger's Avatar
booger
That was my thought . $ 45.00 good investment
Old Nov 23, 2004 | 12:15 PM
cjb80's Avatar
cjb80
Where can I pick up a service manual? Sorry for thread jacking.
Chris
Old Nov 23, 2004 | 05:40 PM
booger's Avatar
booger
I have it on my computer , but its a G35 coupe manual . If you want it , I cant try to send it to your email address . It may be to big . We can try . Pm me your email
Old Nov 24, 2004 | 01:18 PM
booger's Avatar
booger
I talk to SGP today . My block is done and more than likely will not be shipped till Monday . I also called the shop today and the return fuel system is going in today , along with the rear end was pulled and new lsd going in...Bill
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
