What offset do I get? Volk Racing SF Challenge
Old Nov 28, 2004 | 11:01 AM
NORCALSTI's Avatar
NORCALSTI
Default What offset do I get? Volk Racing SF Challenge
ok im lookin at like 19x8.5 front with a 245 35 19 and rear 19x10.5 rear with 285 30 19.
will these fit and clear the lip and brakes? i dont want any rubbing issues.
what offset do i get? i want the fattest amount of lip both in front and rear.
Old Nov 28, 2004 | 11:48 AM
narkotic's Avatar
narkotic
won't be a problem. i have 19x9.5 front and 10.5 rear with +23 offset all around, very agressive for having 4 wheel stoptech brakes.
Old Nov 28, 2004 | 11:52 AM
NORCALSTI's Avatar
NORCALSTI
id go 8.5 front cause 245 35 19 on a 9.5 rim looked stretched to me
as for rear id like to see pics of that
Old Nov 28, 2004 | 04:52 PM
Baumer's Avatar
Baumer
i used to have that same setup..
19x8.5 +21 with 245/35/19
19.9.5 +23 with 285/30/19
No issues with rubbing..
Old Nov 28, 2004 | 04:58 PM
Lucino's Avatar
Lucino
Does anyone know for sure if SF-Challenge comes in 17's?
What's the stock offset on the stock 18's for the 6mt?
Old Nov 29, 2004 | 12:35 AM
NORCALSTI's Avatar
NORCALSTI
wat offset do i use if running a 10.5 rim?
Old Nov 29, 2004 | 01:22 PM
AXA_G35's Avatar
AXA_G35
if you have Brembos or plan to get larger brakes, get 22 or 23.
Old Nov 29, 2004 | 01:44 PM
NORCALSTI's Avatar
NORCALSTI
i have brembos and 19s is perfect im not out for the ghetto look
Old Nov 29, 2004 | 03:32 PM
1nate7's Avatar
1nate7
LOL, he was talking about the offset, not wheel size.
Old Nov 30, 2004 | 01:05 AM
NORCALSTI's Avatar
NORCALSTI
WILL 10.5 fit in rear
Old Dec 2, 2004 | 11:46 AM
Dragonstyle's Avatar
Dragonstyle
I belive 10.5 inch rears will fit.....but it also depends on your tire size and how dropped you are since you may need to pull/shave your rear fenders a bit to fit the bigger tires for a 10.5 rear......just my thoughts......I'm sure the owners with 10.5 rears can help you out more....
Old Dec 2, 2004 | 11:56 AM
NORCALSTI's Avatar
NORCALSTI
well i looked at the tire specs 285 35 19 fits from 9.5-11 rim so ill just do that.
now what offset do i get in rear so i get the fattest lip and still not rub?
Old Dec 2, 2004 | 12:45 PM
RCKTDAWG's Avatar
RCKTDAWG
You mean 285x30x19. Call mike at REVHIGH.com he has the experience
Old Dec 2, 2004 | 12:51 PM
NORCALSTI's Avatar
NORCALSTI
no 285 35 19 cause i want to keep about the same rear tire height
245 35 19 and 285 30 19 are same height i want a little taller tire in rear.
front
225 45 18= 25.9 stock
245 35 19=25.7
rear
245 45 18= 26.6
285 35 19=26.8
Old Dec 2, 2004 | 01:04 PM
RCKTDAWG's Avatar
RCKTDAWG
so whats the diameter of 285x30x19?
Old Dec 2, 2004 | 01:06 PM
NORCALSTI's Avatar
NORCALSTI
its same as 245 35 19 sorry but i want a fatter tire in rear
Old Dec 2, 2004 | 01:13 PM
djricepik's Avatar
djricepik
I am running 9.5 in front 10.5 in the rear - +17 and +19 offsets respectively on 19" Volk SF-Winning wheels. I have HUGE lips 3" FR and 4" rear. I have not had to roll/shave/pull my fenders, only because after lowering the car the camber is all out of wack, and I am running a 275/30 Falken Azenis ST-115 in the rear. This tire is narrower than most, so it is stretched a lot. Maybe not the ideal setup for everyone, but it works for me.
If you want to go super agressive, my setup is what you are looking for... Here is a pic... better one to come.
Old Dec 2, 2004 | 01:25 PM
NORCALSTI's Avatar
NORCALSTI
ok soooo 10.5 woudl rub with 285
ok so front im sure i want 8.5 rear 9.5 now what offset do i get so i get hte biggest lip
Old Dec 2, 2004 | 01:26 PM
NORCALSTI's Avatar
NORCALSTI
actually if 10.5 would fit on rear with 285 id do it but i htink it might be close.
Old Dec 2, 2004 | 01:35 PM
RCKTDAWG's Avatar
RCKTDAWG
I just got off the phone with Mike at RevHighOnline.com I changed my order I will be running 9.5 & 10.5 Volk LEs, 255X35X19 AND 285X35X19. The g-Force T/A KDW-2 come in both sizes (which is very, very rare). The fronts will be .105 taller and the rears .190 taller than stock. He told me thay will absolutel not rub with the LEs +22.
