header problem-car dies after startup
Old Jan 4, 2005 | 01:04 PM
Ant830's Avatar
Ant830
Crawford Plenum, Kinetix Cats, Injen CAI, Custom Y-pipe, and the Headers...pretty much need exhaust and the ECU. Both are expensive at this point though.
Old Jan 4, 2005 | 01:20 PM
Razorx35's Avatar
Razorx35
You know, I have the same problem. It started after I had the installed the Kinetix plenum. I already had:
Injen CAI, Stillen dual exhaust, Kinetix High flow cats, light weight fly wheel, and UR pullies.
I just figured it was the because of all the mods as well. I'm glad to now I wasn't the only one to have this problem. I just blip the throttle when I go to restart after the car is warm. When it's cold it has no problem. With the headers added to mix, it hasn't changed. But I figured I'd have it fixed when I go and get the ECU re-flashed at Techno-square.
Just a little more info for you guys. Oh! and buy the way, I haven't noticed any loss in power. The power just seems to keep going up.
Later,
Ray
Old Jan 4, 2005 | 03:05 PM
djricepik's Avatar
djricepik
Originally posted by g35twinturbo
The "thing" Eric is talking about that raises the idle is soo tight i believe its called somthing like a OBDII (dont quote me on that but that is a tool that infiniti and nissan use on even stock cars.
OBII- on board diagnostics 2
This is a way to monitor emissions in your vehicle with 2 O2 sensors- pre and post cat. This has nothing to do with Technosquare...
Old Jan 4, 2005 | 04:03 PM
g35twinturbo's Avatar
g35twinturbo
actually i think ur wrong. Its a diagnostic tool that infiniti and other shops use. This tool will allow you to raise the idle.
Old Jan 5, 2005 | 07:33 AM
djricepik's Avatar
djricepik
Actually, I'm not...
What is OBD-II?
On-Board Diagnostic systems are in most cars and light trucks on the road today. During the '70s and early 1980's manufacturers started using electronic means to control engine functions and diagnose engine problems. This was primarily to meet EPA emission standards. Through the years on-board diagnostic systems have become more sophisticated. OBD-II, a new standard introduced in the mid-'90s, provides almost complete engine control and also monitors parts of the chassis, body and accessory devices, as well as the diagnostic control network of the car.
you can read the rest here....
What is OBD-II?
You probably saw them use a scan tool to see what code you were throwing...
Old Jan 5, 2005 | 03:05 PM
jim@streetimage's Avatar
jim@streetimage
Actually the car was not giving any obd2 codes at all. What Eric was refering to is called the Consult 2. It makes a typical scan tool look like a fisher price play toy. It can tell you everything that is going on on your cars CAN system and allow you to update and adjust different parameters. That thing is worth some loose pocket change. Over 6 grand to give you an idea and every Nissan/Infiniti dealer has one.
Old Jan 9, 2005 | 05:04 PM
Ant830's Avatar
Ant830
well I got this problem fixed by raising the idle a tad but I still have a pretty big problem...car sounds a little raspy. I was told by Eric that it could be because of the HF cats but I'm thinking it could be my 'custom' y-pipe...He told me there are small leaks coming from the y-pipe not fitting perfect. I'm thinking about putting on the stock Y-pipe and seeing if that makes a difference. I know with any air leaks my car sounds raspy (seeing as how there was a bolt missing in the y-pipe a long time ago and caused a horrible rasp). What do you guys think?
Thanks for all the responses
Old Jan 9, 2005 | 08:29 PM
SponGer's Avatar
SponGer
What's the diameter of the y pipe? If it's too big, your car will run like crap (lost lots of low end until I got it dialed in). This happened to one of my other cars.
Old Jan 10, 2005 | 01:28 PM
Ant830's Avatar
Ant830
the piping is 2 1/4...Eric said there were small exhaust leaks at the flanges though...which makes me wonder if that's what's causing the rasp.
Old Jan 10, 2005 | 05:48 PM
Poptarts's Avatar
Poptarts
ive got a quetion for the people with plenums. Ive got a Injen CAI now and was looking at buying the kinetix high flow cat and plenum combo. Will this upgrade cause any problems such as mentioned above?
Old Jan 10, 2005 | 08:03 PM
imalazeeass's Avatar
imalazeeass
Dont know about the cats, but the plenum installed perfectly fine and sounds nice! But then again, I don't really know what "rasp" sounds like so I may be having it without even knowing? Anyone wanna clarify as to what raspiness sounds like?
Old Jan 10, 2005 | 09:32 PM
SponGer's Avatar
SponGer
A good exhaust shop will be able to get rid of the leaks. Not only will your car run better, it will be a step in the right direction to getting things sorted out.
Old Jan 10, 2005 | 09:33 PM
SponGer's Avatar
SponGer
Listen to a Honda with the coffee can hangin' out the back.
Old Jan 10, 2005 | 10:37 PM
Ant830's Avatar
Ant830
rasp is pretty much anything that doesn't sound stock or deeper. It sounds more high pitched like a metallic sound. I'm thinking of just throwing on the stock Y-pipe to see if that does anything.
Old Feb 9, 2005 | 08:10 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
jus' remember, after installing all those things to make your car breathe better, you will run pretty lean....somewhere in the 14's, which is pretty bad. there's lots of threads around here about it.
n1cK!
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
