JIC FLT-A2 or Flex+EDFC?
Old Apr 21, 2005 | 07:29 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by G35cTT
here's a picture of them installed. I don't really dig the color of them but they work really good. Does anyone else have these??? Just wondering
You have the only known G35 running KW coilovers. You may or may not gain from attempting to set the compression and rebound damping. If you wanted to try go here find out how to do it right and skip to page 13
http://www.koni-na.com/pdfcatalogs/K...ortCatalog.pdf
Here are your specs in case you wanted to know your spring rates.
KW coilovers Variant's 1,2&3
Monotube construction,
V1=non adjustable dampning,
V2=adjustable damping,
V3=separate adjustability for compression damping AND rebound damping and is the only product of it’s kind at this time.
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Old Apr 21, 2005 | 03:32 PM
G35cTT's Avatar
G35cTT
Right I probably am one of the few that do have them, they work really good if anyone has tried them. My car is missing an engine so when I gtet it all up n running I will try this out. Thanks, their site didn't have very good instructions this is much better is this for KW or koni though?
Old Apr 25, 2005 | 02:36 AM
G35cTT's Avatar
G35cTT
http://www.automotiveforums.com/350z/
here's someone else using them
not the only one now
Old Apr 25, 2005 | 07:00 AM
Gsedan35's Avatar
Gsedan35
He's one of around 3 350Z's that I've know about that are running the KW's, you remain the only known "G35" running them that I know of.
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
zyu
East Canada
Oct 19, 2003 06:45 PM
G35 SAGE
Jul 9, 2003 01:24 AM
Chebosto
May 13, 2003 01:43 PM
Quick
Mar 24, 2003 03:07 PM
