2005 G35 ?'s
Old Apr 25, 2005 | 01:46 AM
overboost's Avatar
overboost
Default 2005 G35 ?'s
I got a quick question. Can a 2005 6spd g35c beat a 350z enthusiast in a drag race? Will the G35's hp advantage over the Z (298 vs. 287) be able to overcome its weight disadvantage?
Thanks
Old Apr 25, 2005 | 08:55 AM
vegaseric's Avatar
vegaseric
I don't know for sure, but I'd think the Z would still beat the G given equal drivers. The Z weighs less and has 14 additional lb-ft of torque.
Old Apr 25, 2005 | 10:15 AM
wnt1bd's Avatar
wnt1bd
drivers race....I beat a 2003 track w/ my G. Didn't blow the doors off , but I was ahead from off the line till about 85 then we shut it down.
Old Apr 25, 2005 | 10:27 AM
Nitrouz's Avatar
Nitrouz
Back to Z
mostly drivers race, but I would give the edge to the Z as it is a bit lighter, has a bit more torque, and has a more evenly distributed powerband if I'm not mistaken. The 298hp vs. 287hp theory is only comparing PEAK hp, but in a race, the powerband is more important and how it is put to the wheels. You can even see that the new track Z with 300 peak hp and a bit less torque (260lb/ft) is still a drivers race with the older engine.
don't believe what you see on paper (or internet). Go try it and find out.
Old Apr 25, 2005 | 12:09 PM
overboost's Avatar
overboost
thanks everybody
nitrouz, I would try it and find out, but I am still trying to decide if I want a G or a Z. When I do get one, I will most definitely try it.
Old Apr 25, 2005 | 12:37 PM
Nitrouz's Avatar
Nitrouz
Back to Z
seems like you are trying to decide based more on performance. Then I would suggest the Z. Even if the straight line is comparable, the twisties are not, unless you upgrade the suspension which you can do for both cars. Good luck.
Old Apr 27, 2005 | 07:40 PM
theguykevin's Avatar
theguykevin
z can take over.
everything is same except G is heavier.
think it simple.
Old Apr 27, 2005 | 11:29 PM
overboost's Avatar
overboost
Originally Posted by theguykevin
z can take over.
think it simple.
Well a 6spd G does have more power than a enth. Z, thats the only reason I asked
JjL
East Canada
Jun 12, 2019 03:04 AM
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
