Stillen Camber / Toe WTF???!!!
Old Jan 14, 2006 | 10:43 PM
tecni's Avatar
tecni
Default Stillen Camber / Toe WTF???!!!
Ok so I bought a set of Stillen Camber adjuster bars because my car sat too low after installing Tein H. Tech springs. I wanted to minimize extreme tire wear and maximize road grip. The day I went to put them in, 1/2 through the install I realized that I was also gonna need Toe arms because the more you try to adjust the Camber, the more you mess up your toe.
So, 430 bucks later I got a set of toe adjusters and installed everything at once but then relized that as much as I tried adjusting the Camber and toe of the rear wheels, the worse it got. Now my camber is so bad that I barely have an Inch of contact with the ground.
Can anyone tell me what I'm doing wrong?
I got the toe corrected allmost 100% but the camber is reeeeeal negative right now and it loks and rides terrible.
Old Jan 15, 2006 | 05:23 AM
cbrflyer919's Avatar
cbrflyer919
whos doing ur alignment?
Old Jan 15, 2006 | 05:24 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
+1
Old Jan 15, 2006 | 05:33 AM
Mike Wazowski's Avatar
Mike Wazowski
+2
I have the stillen camber arms, with the JIC toe arms. If it the person doing your alignment is competent there should be no problems.
Old Jan 15, 2006 | 08:39 AM
tecni's Avatar
tecni
I installed the arms and I was trying to get it as aligned as I could before I took it to a shop to get it done profesionally. Plus, its sunday and the place where I usually get it done @ for 35 bucks is closed. I'm gonna see if there's another place open today so I can get that out of the way.
Old Jan 17, 2006 | 12:31 PM
IAPDirect.com's Avatar
IAPDirect.com
Try carlitos tires on Forsyth rd. They do a great job on lowered cars.
Old Jan 17, 2006 | 12:41 PM
roneski's Avatar
roneski
It can be a pain, I spent a few hours messing with mine when I installed them. Remember that the lower you are the more camber you add and it is possible to go beyond the limits of what the Stillen arms can adjust for.
It's a geometry puzzle basically, you add positive toe and you get negative camber. (I think that's how it worked) If I remember right I had to push the toe arm out nearly as far as it would go then adjust the camber arm.
Also you can try loosening the bolts that attach the spring perch while adjusting. That little bit of play that it gives you can help some, but be sure to tighten them back up when you're done.
It's frustrating but it can be done. At least you can get it close enough to drive to the alignment shop.
Old Jan 21, 2006 | 08:31 PM
overZealous1's Avatar
overZealous1
yes there is huge camber and toe gains and losses through the suspension travel. one adjustment effects the other. mine is lowered about 3" all around and i am at max. toe subtraction, but have alot more adjustment in camber with aftermarket links. sucks cause my tires are still cambered abit yet i'm out of adustment on the tow to allow more camber + adjustment.you just need to keep playing with it and record your measurements so you know how far you are moving it. a 2' level will help setting camber, and measuring with a couple framing squares in the front and rear of the tires will give you toe. if you do it correctly, you can get your alignment to 95% before the alignment shop. i have made some "tools" i use to set wheel alignments.
Old Jan 22, 2006 | 07:06 AM
tecni's Avatar
tecni
I ended up taking it to CR alignment on Orange BLossom Tr. and after 4 hrs of dedicated wrenching, they managed to get all my specs in the green and now the car drives perfectly. ALso, I had Tein H and my camber/toe was too off for propper alignment so I went out and got a full tein flex system.
To all those installing their own Tein FLex: Remeber to tighten the top nut on each coilover and soften the shock sensitivity. I had to drop the shocks again after I installed them because I had the washers rattling in the back.
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
