remote fob programming instructions 04 g35 coupe
Old May 9, 2006 | 02:48 PM
mutt956's Avatar
mutt956
Default remote fob programming instructions 04 g35 coupe
Does anyone have a copy, or a link to, instructions on how to program the keyless remote? i got a 04 g34 6mt coupe, but remote isnt working.
thanks!
Old May 9, 2006 | 03:49 PM
Brando's Avatar
Brando
Cool
Try this.....
ok door open... get in... close door.... lock doors... take key in one hand and keyfob in another.... insert key in and out of ignition many times untill the hazards flash... when the hazards flash turn key to on position. and press any button on the keyfob... turn key off and pull it out unlock and open door.
Old May 10, 2006 | 09:47 AM
mutt956's Avatar
mutt956
i tried this today, with no luck hazards didnt flash at all..
any other suggestions?
Old May 10, 2006 | 03:36 PM
HipHopPro's Avatar
HipHopPro
when I needed to program my keyless remote I did what oldvfrguy said, and it work for me.
Old May 11, 2006 | 11:38 AM
mutt956's Avatar
mutt956
dayum maybe my remote is bad....i dont know...
Old May 13, 2006 | 09:35 PM
O NO's Avatar
O NO
REPROGRAM KEY FOB
QX4, 1997-2004 Q45, I30, I35,1999-2002 G20, FX, G35, M45, Most Nissan Vehicles
The horn chirp can be disable by pressing the lock and unlock buttons simultaneously until the hazard lights flash, and no enable press the lock and unlock until the horn chirp.
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side
marker/tail/license lamps and interior illumination will flash twice when this step is
accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:
Do not press the button more than one time in the above step. If the button
is pressed more than one time, the programming procedure will not be successful.
The side marker/tail/license lamps and interior illumination will flash twice when this
step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat
the procedure on step 5 "Additional ID code entry" for each new remote controller.
NOTE:
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Old May 16, 2006 | 09:03 AM
mutt956's Avatar
mutt956
Thank you for the detailed reply. Alas, i cannot get the hazard warning lights to flash. not sure if there is another problem or what.
Old May 16, 2006 | 02:12 PM
O NO's Avatar
O NO
NP, I would suggest to do a search here and on g35driver to see if anyone else has had this problem.
Jambo016
Sep 16, 2016 01:08 PM
seagrasser
Oct 11, 2015 03:27 PM
nanotech
Oct 2, 2015 05:02 AM
