Pop Charger/Stillen High flow.
Old Jun 16, 2006 | 04:33 PM
skc's Avatar
skc
Default Pop Charger/Stillen High flow.
What's the differences/advantages/disadvantages between the popcharger and the stillen high flow? any suggestions? (right now im just running the ztube w/ k&n drop-in) thanks
Old Jun 16, 2006 | 06:55 PM
Mike Wazowski's Avatar
Mike Wazowski
https://my350z.com/forum/search.php
Old Jun 16, 2006 | 08:39 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Im guessing you have a G35. Honestly, the stock intake system is already a great design but there is always room for improvements even if it is only a slight gain, other bolt mods will eventually enhance the gains of your intake depending on what other mods you do. It all comes down to if you think it is worth the money. The Stillen intake comes with a urethane air box that is suppose to keep intake temperatures down, same functionality as the heat shield that is provided with the Pop Charger. The Pop Charger I would say sounds more aggressive than the Stillen unit but both intakes will probably give you about the same amount of gains, but the Pop Charger is cheaper!
INTAKES
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
