Why can't I just change the pads?
I am not going to spend 2500 for an OEM brake replacement, and buying aftermarket rotors is not exactly cheap either. Why can't ppl with brembos just change the pads? my rotos look fine to me, and I see no reason to change them.
My question is, will anything happen if I go ahead and leave the rotors and just get pads?
Guest
Posts: n/a
2500 is crazy
try the stoptech stage 2 for the G. i think the brembo version is maybe $700
you get pads (axxis ultimate) rotors (slotted or drilled your choice) SS lines and motul fluid. its a great value!
http://www.mynismo.com/products/?ID=2966
Guest
Posts: n/a
Originally Posted by 1nate7
Brembo option is actually $1,500. Inspect your rotors, they might be fine and just get some new pads.
the 1500 price is for the aerorotors i believe
the 700 price is for the sportstop direct replacement
http://www.stoptech.com/products/rotors.shtml
http://www.stoptech.com/user/SearchProducts.asp
Originally Posted by mc350z
thats my job!
yeah its all 4 rotors. what year is your G?
ive got the non brembo version on my Z. its a nice set up
Since u already have these, is there any squeeking from the brakes? I know some aftermarket setups squeek a lot.
Guest
Posts: n/a
well i autocross alot and my pads are almost dead so im getting a little noise now but brand new everything felt and sounded fine. you will notice a firmer feel in the peddle with the SS lines. the axxis ultimates are a pretty good street pad. and a little less dust than stock. plus the slotted rotors are gonna give your car a sportier look
you should have a similiar experience with the brembo version.
$2500, WTF??
When my rears were low, I picked up some Project MU pads for ~$90. The rotors were still good, just have them resurfaced. If you don't know how to change the pads yourself, labor at any shop should be ~100 including resurfacing the rotors. So with pads and labor, you should be looking to spend under $200.
I wouldn't go around spending several hundreds or even thousands on replacing rotors or "upgrading" brakes unnecessarily. Once your rotors are gone, then get new ones. But the stock ones are good for at LEAST 1 resurface, depending on conditions, you can probably get 2 out of them.
Once my rear rotors were gone, I pickd up some Brembo slotted rotors for like $300. The fronts are roughly the same price for the pads and rotors, maybe $10-20 more for the fronts.
I don't autocross, but I do track on road coarses. The craziest day was when we only had like 25 cars, so we only did 2 run groups. Thats 30 minutres on the track, 30 minutes off, then back on again. My brakes did not fade even once, then ENTIRE day. From 8am - 5pm. I really don't see much need to extensively upgrade the OEM Brembos. I am very satisfied with their performance considering they are an OEM part that came with the car. Since then, I have only upgraded the pads, and have noticed these pads last much longer than stock, and have a stronger initial bite, and still do not fade. I have also switched to slotted rotors, and I might go SS lines and better fluid in the future when I have time to bleed my fluid.
All in all, I would suggest just changing the parts as needed, and spend your money elsewhere. My entire setup, pads, fluid, lines, rotors for all 4 corners if I were to do it all at once would be around $950-1,000. But I just do it as th stock parts wear out, then replace with aftermarket/performance.
Let's see if Mr. mc350z agrees with me.
Brake rotors and brake pads need to be broken in. This applies to resurfaced rotors too.
In the quest for gas mileage the manufactures have cut weight where ever possible. In my experience with brakes, rotors are as thin as possible when new. This applies to a G35 or an F350 Diesel.
My suggestion, if there is no pulsation when you are braking, just slap pads on it. The rotor will already be broken in and all you have to worry about is the pad.
Guest
Posts: n/a
well i only resurface when i have to. and instead of even attempting it on my OEM rotors i jsut opted to but new slotted ones.
if i can get by with just breaking in pads then thats what i do. usually you can turn rotors one or even maybe 2 times in their life depending on what kind of abuse you put them through. im not really a brake expert but i dont think its necessary to turn the rotors everytime you change pads unless you are getting alot of steering wheel vibration when braking.
im about to switch pads in a month and ill probably just do the pad break in and not fool with my rotors. but that just my opinion
no, you are correct it is not necessary to turn the rotors everytime you change the pads. This is something that has just worked its way into peoples heads over the years because most everyplace that does brakes tells you that it needs to be done. It is an easy way for them to make a buck off of people.
If there is sufficient thickness left and there is no other problems, you will be good to go with just new pads.
I always resurface my rotors everytime I change my pads.
I do them myself, so I am not getting suckered by some shop wanting my money. Even if the steering wheel doesn't vibrate like crazy, your rotors are still not true and flat.
If anyone here has ever operated a brake lathe, then you know what I'm talknig about. You can see the uneven areas when you cut it, even if you can't see it with your eyes, or feel it with your hands, its uneven.
It could just be personal prefrence, but I like to have a flat rotor if I am putting in a new flat pad, to maximize the contact area.
How many miles did you put on this setup? Thanks!
Performance Nissan
Performance Nissan
the cost of OEM rotors and Pads is very expensive... looks like they are also charging you alot of labor to boot...
There are 2 stage kit options available as mentioned above...
they can also be purchased here...
http://mynismo.com/products/?id=2966
Regardless of the pads you choose, if you are not using new or resurfaced rotors, you will be more prone to dust and noise.
Your old material is embedded in the rotor for at least the next 500 miles, possible more if it continues to get pushed into them and the pads will not have a perfectly smooth surface to break into leaving the new pads with an irregular surface and prone to noise.
Chris
Chris
Chris
Chris
I don't know about your fist statement....
Next time you take your rotors to Autozone to get resurfaced try this. When you get home get a good stiff brush, some dishwashing soap, and a good garden hose. Wash those rotors. You will be amazed at how much metal comes off that rotor.
I know a lot of you are too young to know what a record is but, when a rotor is turned the carbide bit cuts grooves into the rotor. The metal filings will get into these grooves. On your first brake application that metal will get shoved into the pad. When I do turn rotors I always do a NON DIRECTIONAL FINISH and wash the poop out of those rotors.
I am also still a firm believer in that if there is no pulsation, don't worry about it. Pads and rotors break in together. Street pads are basically the same, so it stands to reason that the rotors are already broken in at the time of a brake job.
