Question for the G35 6sp owners
Did a search, couldnt find any info. But I remember looking at the Inifinite site, where you can build/price your G35, and I believe I remember it saying that the G35 6sp comes with a dual disc clutch? Please correct me if I'm wrong, but I was wondering today after talking to some friends. I went back to the Inifinte page, and found nothing. Curious if any of you G35 owners know for sure. Thanks for the info!
the most common name is G35 6mt. i have an 05 and yes i believe that it does have a dual disc clutch. should be the same as the transmission in the 350z
edit: sorry, dual mass flywheel is what i meant. got confused
Originally Posted by ZFreak (Denver)
dual mass flywheel (just really frickin' heavy). I ditched the tilton, and back to JWT/Nismo setup.
Originally Posted by Mid117
jwt chatters a lot
Yes it is a chatterbox, but that's not something that bothers me a "lot"....the tilton, that's just insane amount of chatter though.
Here ya go:
http://homepage.mac.com/stracy01/G35...oAlbum112.html
Scroll down, you can see my toasted OEM clutch (dual mass flywheel, stage 1 clutch) and the JWT replacement (Al Flywheel), 1200 kg replacement clutch. The NISMO R-Tune clutch by comparison has 1000 kg clamping force and costs considerably more. I looked at many options for a streetable solution and found JWT suited my needs well. NO regrets, it is great and with the something like 70-80% reduction in flywheel mass, the rev up/down is noticeably better. JWT also has a replaceable friction surface, that may save some headache later.
Not surprised, Infiniti dealer didn't want to know anything about other than OEM when I replaced mine. OEM is a cheap ($180 clutch, $90 PPlate), heavy POS shared part that is used in several other Nissans. I think the thing is deliberately under-spec'd to avoid transmission warranty issues, which were a big deal in 2003 for Infiniti on the G Coupes.
BTW flywheel chatter from inside the G Coupe can barely be heard on mine at stop, once moving it is not audible. Chatter is a personal preference; the sound is not loud, not "grating" outside the car even. The OEM flywheel is a PIG at ~32 lbs and even the NISMO flywheel costs way too much to cut all of ~4-6 lbs (a whopping ~15-20% reduction for over $500). The OEM dual mass flywheel just uses a lot of heavy steel crap to smooth out vibrations in the pursuit of the car you cannot tell if it is running at idle. My OEM clutch died after 31k miles, I have never been hard on clutches in a number of rides, several of them Nissans. Stop and go traffic is a killer, slipping in 1st is sure to create that nice burnt clutch smell.
BIGGEST change that I never noticed prior to the swap was how the OEM clutch ALWAYS had more "give" or slip changing gears, very noticeable now that its gone, I just get very positive engagment. Tricky for the first few hundred miles, then you get used to the more positive engagement. I don't know if this is considered Stage 1 or 2, but it is not Stage 3 and very street-use friendly. I spent $800 for flywheel and clutch; OEM from the dealer, the flywheel was $1100, clutch kit $270, labor $500.
I said, no thanks, find another way somewhere else.
My 2004 G-Coupe is still much quieter than my 2003 350Z; inside and out that was one mechanically noisy car.
Originally Posted by jjellyneck
How's the overall responsiveness of the JWT flywheel vs. stock? How much noisier also? Thanks.
If you want "Camry Quiet", get a Camry...
Originally Posted by SpeedRcr
its a dual mass flywheel, the clutch disc is just a regular disc. All G/Z have the dual mass flywheel to absorb sound compared to a single mass flywheel
All Pics:
New JWT Clutch & Aluminum Flywheel
Vigman
Nov 17, 2015 04:34 AM
