Drift..............
Old Aug 1, 2003 | 09:21 AM
racingdynamcs's Avatar
racingdynamcs
Default Drift..............
anyone try to get some drifts in with their g35c??
i'v done a couple at auto X and it feels like the car is in total control unless u give it to much gas ill spin out....
perfect car for drifting...
Old Aug 19, 2003 | 05:14 AM
ImportFreak's Avatar
ImportFreak
the g is a little heavy but the biggest problem is the ****ign vdc that wont turn off completely.
Old Aug 19, 2003 | 06:36 AM
racingdynamcs
all that is ********.... i wip out the 350gt for drift so easy and nothing can stop the drift unless u get off the gass...
Old Aug 19, 2003 | 09:59 AM
D_Nyholm's Avatar
D_Nyholm
I felt that the G was very stable in a drift. When I was autoXing, I had no problem feeding in a little extra gas and gertting a controlled oversteer situation going on. IT was alctually a lot of fun and it saved me a few times instead of plowing into cones!!
Old Aug 19, 2003 | 03:59 PM
racingdynamcs
its great auto X car for its massive size!
i ran .3 sec off a M-Roadster and it was my 1st time auto xing
Old Aug 20, 2003 | 08:47 AM
FiddlerG35c's Avatar
FiddlerG35c
go to www.importfanatix.com for some recent drift pics.. a few are of me attempting to drift.. the car understeers way too much so it's difficult to get a controlled drift ..... the only way i managed to throw the rear out is to do a clutch - drop in mid-turn ...
at first i thought it was just lack of experience (which is definitely contributing to my suckiness), but one of the more seasoned drifters tried going in my car and had a tough time as well ...... now i'm waiting for my rear cusco anti-sway bar.. that should help things a little..... also would be nice to get some crappy rubber on the back tires.
Old Aug 20, 2003 | 09:28 AM
racingdynamcs
no crappy rubber will not help...
to do great drifts u have to have good rubber but u have to heat it up a alot to the point where is going to start losing traction...this way ur have a slide and grip...i'v done it a few times...seems to work well but very hard to get the tires heated up quickly...
Old Aug 21, 2003 | 05:50 AM
ImportFreak
link doesnt work
Old Aug 21, 2003 | 08:23 AM
Gsedan35's Avatar
Gsedan35
Not that I want to, not that I give a darn, but with the Cusco sway bars I added, I can drift very easily. And I actually drive a sedan, not a coupe, without LSD even.
Old Aug 23, 2003 | 08:15 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
im getting the sways after my wheels get off the boat, they should help teh car drift alot.
Old Aug 23, 2003 | 08:21 AM
racingdynamcs
which sways did u go with ?
cusco or nismo?
Old Aug 23, 2003 | 02:10 PM
riffster's Avatar
riffster
I have autocrossed my coupe for most of the summer and found fairly easy to drift .... IF there was the kind of corner that permitted me to get up enough speed to use lift-throttle understeer to position the original drift followed by underdoing the counter-steering a bit.
The problem is most AutoX courses are too tight (at least in my region) for this so drifting would hurt me by making me hit cones.
There is a video out there - I will try to find it. It shows a Skyline Coupe drifting through turns at very high speed (obviously a professional driving) while leading an IS300, an RSX, and a Subaru WRX in a race sponsored by a Japanese car mag.
- Riff
P.S. The other cars were taking conventional racing turn-in/apex/turn-out lines into each corner!
Old Aug 23, 2003 | 03:01 PM
riffster's Avatar
riffster
- Riff
P.S. The other cars were taking conventional racing turn-in/apex/turn-out lines into each corner! [/B]
Here's the video - correction on the race - it did not involve an IS300 - there were an Integra Type R, WRX, and an RX-8. There were also an S2K and a Miata involved but you don't see them in this short video.
Sorry, it's on Imagestation so you'll have to have a login - it's the first video. Note the very cool drift by the CB coupe as it leads the vainly pursuing Acura, Sube, and Mazda!
http://www.imagestation.com/member/join_signin_prompt.html?album_id=4289934725&bnak=1&rf=album& ru=%2Falbum%2F%3Fid%3D4289934725%26bnak=1
Enjoy. (Hope this hasn't been posted here before!)
- Riff
Old Aug 24, 2003 | 04:07 AM
ImportFreak
link wont work for me
Old Aug 24, 2003 | 08:25 PM
riffster's Avatar
riffster
Sorry about that - the reason why it didn't work was because of the wrap on the URL ImportFreak.
It will work if you highlight both lines and then copy and paste them into a new browser window.
Btw, there are many more videos than just the brief one showing the G drifting - they are all entertaining but are unfortunately narrated in Japanese.
(Remember to right-click and then select the "Save Target As ..." when you see the second Download Video prompt. Imagestation does not support streaming video - you'll have to save it to your hard drive, then watch later after it finished downloading.)
Good luck and good viewing!
- Riff
P.S. Props to my fellow coupe driver Suke and some other coupesters for capturing and transferring this video to the proper format.
