350z springs on a G35?
Old May 3, 2009 | 07:45 AM
06daytona's Avatar
06daytona
Default 350z springs on a G35?
Hey i guess this could go under the tech section, but i just got an 06 G35 4dr for the wife and i have my 06 350z stock springs just laying around. does anyone know if you can put the 350 springs on the G and how much would it lower the G if it would work. i really dont want to do much to the G but since i have the springs sitting in the garage i might as use them if i could
Old May 3, 2009 | 09:33 AM
urbanchaos's Avatar
urbanchaos
stock springs wont lower it much if any
Old May 3, 2009 | 09:35 AM
06daytona's Avatar
06daytona
i didnt know cause my stock Z sat lower than the stock G
Old May 3, 2009 | 09:55 AM
- bigc -'s Avatar
- bigc -
there's a stickied thread on G35driver.com that will tell you exactly how much any type of z spring will lower your car. IIRC, its in the tech section under brakes & suspension.
Old May 3, 2009 | 03:21 PM
tiguy99's Avatar
tiguy99
False.
Stock 350z springs lower the G sedan 1" and the G coupe .5"
I'm using 350z revised springs on my G coupe right now. Same exact ride I had before (05 sport G35 coupe premium w/factory sport suspension)
No camber kit is needed to lower the coupe but I'd get one for the sedan for sure.
Old May 3, 2009 | 05:31 PM
06daytona's Avatar
06daytona
Originally Posted by tiguy99
False.
you think 1inch would cause for a camber kit? i understand on my Z but i had a honda accord with 1 1/2 inch drop and no camber kit and never had issues
Old May 4, 2009 | 07:29 AM
SpeedRcr's Avatar
SpeedRcr
the z springs will give a .5 inch drop on the g
Old May 4, 2009 | 12:12 PM
06daytona's Avatar
06daytona
Thanks guys i went to g35driver and found the info i needed. i might as well use them on the G since they are collecting dust in a box
Old May 4, 2009 | 12:25 PM
tranceformer95's Avatar
tranceformer95
False.
Sounds about right. I sold my stock suspension from my '05 350z to a friend. He installed them on his '04 G35 sedan, gave it a considerable drop.
Old May 14, 2009 | 06:37 AM
SwivelMan's Avatar
SwivelMan
1" all around. OP - Swap the shocks, too, though since the stock G sedan shocks are not up to the spring rate of revised Z springs. Sport sedan springs - the red ones - are fine for unrevised Z springs, since unrevised are a bit lower rate and sport shocks can cope with them fine.
Definitely hit up the sticky on G35Driver if you're at all unsure.
Old May 14, 2009 | 09:38 AM
tiguy99's Avatar
tiguy99
Yup...any drop over .5" will throw the alignment out of spec w/o the proper camber kit for our Gs/Zs
Originally Posted by SwivelMan
1" all around. OP - Swap the shocks, too, though since the stock G sedan shocks are not up to the spring rate of revised G springs. Sport sedan springs - the red ones - are fine for unrevised Z springs, since unrevised are a bit lower rate and sport shocks can cope with them fine.
Yeah the unrevised springs were way too soft and bouncy when I had them on my G coupe sport for a few days.
I got rid of them because one day on the expressway I was driving home and hit this normal dip in the road I pass all the time....
Only this time I bounced out of my chair and hit my head on the ceiling. I knew what I had to do after that point
When I switched the the revised springs the ride went back to how it was before I did the drop in the first place since my car came with the revised sport suspension shocks
Old May 21, 2009 | 10:17 AM
Allshow's Avatar
Allshow
tig how do you like the drop with the revised springs. im thinking of doing this with my coupe and whats the finger gap you have?
Old May 21, 2009 | 08:56 PM
tiguy99's Avatar
tiguy99
I love it! It rides exactly the same as before as my factory sport suspension so I didn't sacrifice any ride quality.
As for finger gap, I'm not sure. Never measured it. The front lowered the most. You can tell its got a drop. The rear settled down somewhat too.
Take whatever the factory height is now and bring it down half an inch and you'll be spot on with where the ride height will be after these
Old May 22, 2009 | 03:19 PM
Allshow's Avatar
Allshow
thanks a bunch ill be planning on doing this since i just want a decent drop nothing major with making slammed
Old May 22, 2009 | 05:31 PM
tiguy99's Avatar
tiguy99
Here's some quick pics taken right after the revised springs were installed. They've settled some more since these pics were taken almost a couple months ago
Old Jun 15, 2009 | 05:42 PM
darnelled's Avatar
darnelled
I have Z springs on my G sedan. It really made the fender gap look much better with no camber issues at all. The ride is rougher, but lots more fun.
[IMG][/IMG]
Old Jul 6, 2009 | 05:57 AM
g35rida's Avatar
g35rida
I'M ON 350Z EIBACH PRO KIT.
Old Jul 30, 2009 | 10:58 AM
oG-35cpe's Avatar
oG-35cpe
350z S-Techs
i put front and rear camber kits to be safe ..SPC
Old Aug 15, 2009 | 12:12 AM
fasttimesNY's Avatar
fasttimesNY
try to check the prices online
Old Oct 15, 2009 | 02:09 AM
kurtdaniel's Avatar
kurtdaniel
350 would definitely be perfect for a g35..ive been using it along with a lakewood shock absorber for two years and it works great..
