vk56 swapping the g
Old Sep 29, 2009 | 11:02 AM
bbs350z's Avatar
bbs350z
Default vk56 swapping the g
hey everybody, been looking recently into swapping a vk56 into the g sedan. ive searched and emailed people that have done this and got no reply. i know the tranny bolts up, etc. but i have read issues about getting the ecu to work correctly.
i am asking what needs to be done in order for this to work in a g35 sedan?
does the engine harness need to be modified to work with the z's 6 speed transmission?
i read about the titan ecu being utilized, but running into problems. is there a way aorund this other than running a complete standalone? and what needs to be customized?
can cruise control/traction control still be maintained with this swap (its my daily)?
please shoot me any and all info! thanks guys!
Old Sep 29, 2009 | 01:36 PM
R350nate's Avatar
R350nate
idk. haha
sounds like a fun swap. subscribing.
Old Sep 29, 2009 | 02:49 PM
quietkilla6's Avatar
quietkilla6
For the money you'll invest in swap and maintenance just get a set if twins. Besides car value goes right out the window with radical swaps like that. Just my $.02 would be cool to see though
Old Sep 29, 2009 | 03:50 PM
warmmilk's Avatar
warmmilk
get a hold of jeremy tibbs, he works at ultimate garage or something like that, used to own performance factory. he did a vk56 swap into a g35 coupe, only one that i know of that actually completed the swap...
cost will prolly be about the same or a bit less than a well thought out fi build, and maintenance will be cheaper and easier
Old Sep 29, 2009 | 04:04 PM
0jiggy0's Avatar
0jiggy0
Because TTing it keeps the value?
Old Sep 29, 2009 | 04:35 PM
Coffeemaster's Avatar
Coffeemaster
Lsx swap it instead.
Old Sep 29, 2009 | 05:36 PM
bbs350z's Avatar
bbs350z
i already got a built tt z. dont want that route, just want a fun dd that i dont have to worry about all the time. reason i picked the vk swap was because ease of ,aintenance and parts, and because it bolts up to the z's 6 speed. just wanna figure out the ecu issues. i pretty much have the motor and tranny, just need the rest of the stuff : )
Old Sep 30, 2009 | 04:05 AM
jksstar's Avatar
jksstar
this post must be a joke. He never completed **** and hacked my car up doing a VK swap. DO NOT USE JT FOR THIS OR ANYTHING IMO.
Old Sep 30, 2009 | 04:13 AM
jksstar's Avatar
jksstar
it does not just bolt up to the 6 speed trans (need a adapter plate) then a custom flywheel and clutch. you will have to run a stand alone unless you use the stock Titan trans and then I'm still not sure if everything would work in the car. Also you need a alot of custom parts built, oil pan, headers, motor mounts and so on.
I have been down this road and I pulled everything out and sold it. It would be a cool swap but for a DD car I would not do it.
Old Sep 30, 2009 | 04:50 AM
GreenGoblin's Avatar
GreenGoblin
Do the LS1 swap instead if you are wanting to do a swap.
Old Sep 30, 2009 | 01:35 PM
bbs350z's Avatar
bbs350z
for cereal? i read that everything bolts up, and the z's clutch and flywheel would work, hence the ease of install, etc. got a link to these custom parts at all?
Old Sep 30, 2009 | 02:34 PM
warmmilk's Avatar
warmmilk
really? i thought they did that g35 drift car that they chopped the top off of? sorry to hear about your bad fortune!
Old Sep 30, 2009 | 07:04 PM
bbs350z's Avatar
bbs350z
well shiiiii send me some info on what needs to be done please!
Old Oct 26, 2009 | 05:24 AM
venommaxr33's Avatar
venommaxr33
talked to a friend that is a tech for infiniti....the wiring harness should fit right up to the stock ecu under the dash. just keep the vk56 harness and plug in. i am looking to do the same raise the compression change a few other things. trying for 500-600whp from the vk!!!
Old Oct 26, 2009 | 07:14 AM
Waiz's Avatar
Waiz
This looks like a good thread with some helpful info:
https://my350z.com/forum/engine-and-...ing-the-g.html
Old Oct 26, 2009 | 07:27 AM
Kwame's Avatar
Kwame
Did you honestly just link this thread to... this thread?
Old Oct 26, 2009 | 10:15 AM
kramykram's Avatar
kramykram
Old Oct 26, 2009 | 11:09 AM
nissansource's Avatar
nissansource
Its a pain in the *** swap. trans will not bolt up and you can use Stock ecu. but if you want i think osiris can take off nats and acouple other things. or you can use the ecu from a Q45 since they have 8 cyl driver and load up new roms with nistune. Ive researched the swap its a great motor with lots of potential and they are wicked cheap. I honestly would do a LS1
Old Oct 26, 2009 | 08:05 PM
bbs350z's Avatar
bbs350z
my plans for this have been canceled. doing a built 5at and newer motor w/procharger
Old Oct 26, 2009 | 08:08 PM
Waiz's Avatar
Waiz
LOL I had both threads open and simply copied the wrong thread.
This was the correct thread that I wanted to post:
https://my350z.com/forum/shop-builds...oked-vk56.html
