vk56 swapping the g
Old Jul 26, 2021 | 02:37 PM
  #41
kel's Avatar
kel
you have to send your ecu to uprev to remove the nats (nissan anti theft system) and have it unlocked to use with your car.
Old Jul 26, 2021 | 02:42 PM
  #42
G3727's Avatar
G3727
Ok so what were you talking about before when you were saying there was some physical modification you had to do to the ecu?
Old Jul 26, 2021 | 03:00 PM
  #43
kel's Avatar
kel
if you mean the nats, that's software. Call uprev and send them the m56 ecu to remove the nats, unlock the ecu, ramove speed liniter etc.. They should be able to put the vin on the g37 to the m56
Old Aug 8, 2021 | 08:07 PM
  #44
G3727's Avatar
G3727
My only other concern is what if any cooling mods you did
Old Aug 10, 2021 | 12:36 PM
  #45
Bridgetown's Avatar
Bridgetown
kel, I followed your build on G35 driver way back. Very cool build. I am starting to plan my swap. Would like to do the VK50VE or VK56VD. This is purely for the higher horsepower spec and twin throttle body intake that has been proven to clear the hood in a Z/G. Seems like it is very hard to find info on this swap, even though I have seen several completed running cars. The main area that lacks info is the ecu options. As far as I can find you are the only VK swap I’m aware of that is running a Nissan ecu. My main questions are:
Was the VK45 ecu in your application communicating with the stock gauge cluster?
Or were you running aftermarket gauges?
Were you able to retain cruise control and traction control function with the VK45 ecu?
my preference would be to run an Nissan ecu (thinking M56 most likely), and avoid the expense of a stand alone system. This seems to me to be the main drawback for this swap.
everything else seems pretty straight forward as far as getting the engine in the vehicle.
Thanks!
Old Aug 10, 2021 | 06:31 PM
  #46
G3727's Avatar
G3727
If you go back a few posts I was picking his brain about the same thing, I’m looking into swapping an engine and awd 7speed from an m56
Old Aug 18, 2021 | 12:31 PM
  #47
kel's Avatar
kel
Thanks!
hey glad you followed the build. if you plan on swapping the VK50VE or the VK56VD, it would have to be on the g37 or 370z. The main reason is because all those cars have an additional ecu to control the variable timing.
Fairlady_06
Sep 10, 2019 06:32 PM
rob2496
Engine Swaps
Dec 19, 2018 06:30 AM
Jesus Tejada
Engine Swaps
Jan 12, 2017 02:56 PM
Shahar Siboni
Aug 19, 2014 06:35 AM
MeinVinyl
Sep 21, 2011 05:59 AM
