Transmission Compatibility AT
Old Dec 28, 2011 | 01:42 PM
CLyons0203's Avatar
CLyons0203
Default Transmission Compatibility AT
I have some serious transmission problems and hope you can help. My car is 05 G35 Sedan RWD auto. The car had a slight shudder (40mph going up hill with light throttle). About a year of that the car is now bumping hard into gear. Sometimes its smooth sometimes it hard. Sometimes the car seems to slip in between gear changes, rpms go up, then bam hard shift. The car has two codes for hi low clutch solenoid valve circuit and clutch valve operation. The fluid has been changed 3 times in the last 4 years.
Long story short, I think the valve body slowly went bad and with me driving it, the clutches are burnt. Fluid that's only 1 month old has already turned black.
So I have been looking for a used transmission as I cannot afford a $4000+ rebuild or re-manufactured unit. I know the 03-04 transmissions are different with external TCM. When I run a search on car-parts.com. Looks like the 05 is different from the 06 and the coupe is different from the sedan and the Z is different from both. I dont see how one could be different between 05 and 06 or sedan and coupe. The only differences between 05 and 06 is the rear differential ratio.
Can an 06 transmission go into an 05 car or a coupe transmission go into a sedan or Z? a reflash of the eprom should code it to work right?
Old Dec 29, 2011 | 01:57 PM
rcdash's Avatar
rcdash
Unless you are looking for a performance rebuild, I don't think it should cost you $4k. I am not certain about compatiblitity beyond what you mentioned. I think it would work, but am not 100% certain that the ECM signal patterns to the TCM are identical year to year (but maybe they don't have to be). I would recommend talking to a transmission specialist that has worked on the RE5R05A.
Old Dec 29, 2011 | 04:58 PM
CLyons0203's Avatar
CLyons0203
Do you know of any specialist?
Old Jan 13, 2012 | 02:29 PM
yosip1115's Avatar
yosip1115
Sounds like a bad tune to me... Have you done any ecu work?
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
SharX59
Sep 27, 2015 09:23 AM
