Anyone lower their g35coupe?
Old Feb 14, 2004 | 03:57 PM
Tailspinz's Avatar
Tailspinz
Default Anyone lower their g35coupe?
If yes.. how much did u drop it ? I think that the car needs to be dropped anyways i lowrd my z 1/24 inch in back and 1/12 in fronts,, can i go lower with the g35c? also what is a good suspension and how much $$ am i looking at roughly? I preffer adjustable springs i live in Canada and when it snows i don't want it to low...
Thanks
Old Feb 15, 2004 | 05:39 AM
Eagle1's Avatar
Eagle1
Many of the spring kits lower the car, as do the more complex coilover damper set ups. About an inch all around is what folks have been doing typically. More than that and you have the risk of chin scrape on the dips at road intersections and driveways, and belly rub on the little speed bumps. Eibach pro kit springs are pretty popular, and some of us are using the Teins.
Some kits are adjustable for height, but you are going to have to lift the car to do it manually. Even the Teins which electronically adjust the damping force, do that through the damper strut, not the springs, and therefore do not impact the ground clearance or height.
Old Feb 15, 2004 | 08:02 AM
Tailspinz's Avatar
Tailspinz
Thanks alot for this... I will drop it by the summer 1" all round
Old Feb 15, 2004 | 10:59 AM
booger's Avatar
booger
I have been thinking of lowering my G .Would like to know ...Want if any it affects the , ride, alignment , suspention ???I know sooner or later Im adding sway bars....but not sure on the lowering thing...any help ?
Old Feb 15, 2004 | 05:07 PM
weslutes's Avatar
weslutes
The Tein basics are great,they are priced low and are easy to install yourself.You can adjust them to stock height untill you can afford the suspension bars,then look into getting sway bars.
Old Feb 15, 2004 | 05:50 PM
VQ35Kompressor's Avatar
VQ35Kompressor
Espelir springs will lower your ride 1.9 and 1.7 in the back. Maybe I might go to the Tanabe springs which lower the front 2.2 and the rear 1.7. Looks more even that way, we'll see. And it rides good on stock shocks. So maybe that's an option for you. I'm also rolling on Work 20x8.5 frt and 20x10.5 rr. Good luck!
Old Feb 17, 2004 | 07:47 PM
cupid's Avatar
cupid
Got Tein S.Tech on mine, ride is still stiff and same as stock springs.
About 1.2" drop in the front. Very happy with the choice.
Old Feb 18, 2004 | 05:04 AM
theeggman's Avatar
theeggman
I dropped mine with the Eibach Pro Springs. The ride is almost stock but it looks and handles much nicer. IMHO.
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
