Question about Nav System????
Old Feb 26, 2004 | 05:23 PM
TampaS2K's Avatar
TampaS2K
Default Question about Nav System????
I just put a deposit on an 04 6mt coupe. Question is if I should get the navigation?
I was planning on getting it after I bought the car, but the salesman told me I had to get it when I purchased it, because they cannot install the navigation after I purchase it. They said it was pre-wired and could not be installed later.
Is this true?
Nick
Old Feb 26, 2004 | 06:32 PM
RashMan14's Avatar
RashMan14
yea i heard this also. SO i got it. Its real nice. I keep the Nav screen always up becuase it has the fuel economy there as a option. The cool thing about it is when you push the gas there is a picture of the leaf and it goes up and down as you gas the car.
And when you add the ty tuner to it (aftermarket one) then its hella nice. Watch laker games all the time from school to home.
Old Feb 27, 2004 | 11:31 AM
FzyLgic's Avatar
FzyLgic
If you want the factory Nav - order it with your car... it's way too expensive to add it on... 2x or more the initial cost
Old Feb 27, 2004 | 06:04 PM
bz8's Avatar
bz8
Default Re: Question about Nav System????
Is this true?
Nick
It's true, the nav uses a different electrical harness then the non-navs. If you want to install it after your purchase your car, you're going to have to pull out the old harness and replace with the nav harness, plus your going to have to change out your dash plates too. Like FzyLgic said, it's way too expensive to add on unless you do an after market, that's expensive too. If you do aftermarket, I heard that the Pioneer makes a real good one. Hope this helps.
Old Feb 29, 2004 | 10:51 PM
Sam56n's Avatar
Sam56n
get the car with nav,
then get a dvd and tv hooked up
then crash into the car infront of you
(ok skip the last thing)
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
