NISMO Low Temperature Thermostat
Old Apr 13, 2004 | 09:32 AM
esemes's Avatar
esemes
Default NISMO Low Temperature Thermostat
anyone using a low-temp thermo???
i have used em on watercraft before, but none in the automotive field...
im thinking, with FI, (and the enemy of heat being even more of an issue) a LT thermo would be perfect....
thoughts??
Old Apr 13, 2004 | 10:54 AM
2003z's Avatar
2003z
I'm running it with my supercharger and like it.
Old Apr 13, 2004 | 08:47 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
anything that allows the engine to run cooler is definitely a plus.....but, i'm wondering, if the temperature setting lower, thereby causing it to cycle more, wouldn't that add extra "wear and tear" to the part, or maybe even the water pump? or am i all screwed-up?
n1cK!
Old Apr 13, 2004 | 09:00 PM
esemes's Avatar
esemes
n1cK!
OR...........
would the ecu , thinking its cold, try to get the motor to the ideal temp (thus richening the mixture??)
i wonder??
Old Apr 13, 2004 | 09:50 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Originally posted by esemes
OR...........
i wonder??
you bring up a real good point! i didn't even think of that! i wonder if nismo thought of that, hmmmmmm............well, 20 degrees is quite a difference...........
n1cK!
Old Apr 14, 2004 | 05:43 AM
2003z's Avatar
2003z
OR...........
i wonder??
No, I'm still running a little lean, for now.
Old Apr 14, 2004 | 05:48 AM
esemes's Avatar
esemes
so, theres no different warm-up ignition and fuel maps the ecu runs during startup??
i dunno, i am just trying to CMA before i buy something *esle)
btw, today is my day... anoincement to follow soon!
-eS
Old Apr 15, 2004 | 01:54 AM
Sam56n's Avatar
Sam56n
i bought the thermo 2 months ago and it is still sitting in my garage, i'm still debating to put it in or not
i have a vortech SC and want to do some research first
Old Apr 15, 2004 | 05:07 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
I run one plus the Nismo oil cooler as well. Going to have to lose the oil cooler when we mount the intercooler on our up coming project. Haven't had any negative effects with either. http://www.performancenissanparts.co...roducts_id=263
Old Apr 15, 2004 | 05:41 AM
ranger5oh's Avatar
ranger5oh
I think on an F-body or a mustang LT thermostats do wuite a bit more. Those cars seem to benefit from these cheapy mods quite a bit more than cars like the Z. The Zs engine has been so highly tuned, I almost think something like the LT thermo might be detrimental, at least in the MPG arena. I just dont forsee a big enough HP gain to warrant the install. Comments? Anyone dyno it with just a thermo? I would be curious what the gain is.
Old Apr 15, 2004 | 06:22 AM
Philthy's Avatar
Philthy
Boost Junkie
I don't think the benefit is from a HP gain... If you're going FI, your motor will run hotter, and this mod will help kick in the cooling of the motor sooner, rather than later when it's already running really hot...
A must have for FI, IMO
Old Apr 15, 2004 | 07:24 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
good on a car especially if you are a hard driver... our motors run very hot... any cooling you can do is a plus...
Old Apr 15, 2004 | 05:45 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i'd have to agree with jason and Philthy...if you are running FI, something that would keep the engine running cooler will be very beneficial.
my only concern was what esemes brought up about running rich, but if 2003z is running lean, then there shouldn't be an issue. i wonder if there's any one else who can provide some opinion/proof on this. if it turns out to extend the life of the motor, then it would be a very good mod!
i've been looking into also getting the oil cooler, but for $1200, it better be pretty damn good! i never understood why it was so expensive. it's probably because it's got "nismo" written on it. i mean, it's jus' a sandwich adaptor, a few an fittings, and a heat exchanger! c'mon! but cooler oil makes for a happy engine
n1cK!
Old Apr 16, 2004 | 05:13 AM
Jeff@Performance
Performance Nissan
i've been looking into also getting the oil cooler, but for $1200, it better be pretty damn good! i never understood why it was so expensive. it's probably because it's got "nismo" written on it. i mean, it's jus' a sandwich adaptor, a few an fittings, and a heat exchanger! c'mon! but cooler oil makes for a happy engine n1cK!
I had a hard time putting the oil cooler in my car because of the very high price. It is a nice unit and the quality is unmatched.... BUT... ya'... the price just doesn't work. That said, if something happened to my car, I would put another on. I'm still trying to figure out how to make it work with my up coming TT/intercooler. http://www.performancenissanparts.co...roducts_id=335
Old Apr 16, 2004 | 10:42 AM
esemes's Avatar
esemes
just foundit online for 101$(US)
cheap!!
Old Apr 16, 2004 | 03:03 PM
Sam56n's Avatar
Sam56n
damn, i paid 110 for it,
i guess i have to charge 900 customers today an extra penny!!!
Old Apr 16, 2004 | 06:11 PM
esemes's Avatar
esemes
wow
i was thinking they were more like 150 or so....
110 sounds good to really.....
Old Apr 16, 2004 | 08:33 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
what would the problem be with the intercooler? wouldn't there be enough room to put the cooler in front of the intercooler?
n1cK!
Old Apr 18, 2004 | 07:24 PM
Jeff@Performance
Performance Nissan
n1cK!
We'll have to look really close, but the way the cooler mounts, the precut lines and the overall size leads us to believe we will have to lose it.
Old Apr 19, 2004 | 10:26 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i know this is a little off topic, but i may have found an alternative to that ungodly expensive nismo oil cooler (sorry jeff, jason), and i know a lot of people hate stillen but here's a link anyway.
n1cK!
