does any body know which wire is tachometer signal from ecu or other way....
Old Aug 24, 2004 | 02:43 AM
toylee's Avatar
toylee
Default does any body know which wire is tachometer signal from ecu or other way....
hello guys..
Does anyone know what wire is the tachomerter signal wire from ecu or other way to get the signal. i try to find that answer all day but still no answer. i got 12v,ground,nightlight wires and mounted on front dash. it is ready to use. but no signal.......
2004 g35coupe manual
thanks
Old Aug 24, 2004 | 09:33 AM
toylee's Avatar
toylee
anyone
Old Aug 24, 2004 | 09:53 AM
jpc350z's Avatar
jpc350z
Default RPM SIGNAL
Originally posted by toylee
anyone
If the G35 ECU is identical to the Z's it wuold be pin #13 (white/blue) crank sensor. This from the Vortech s/c install instructions..
Old Aug 24, 2004 | 11:36 AM
lorinserbenz's Avatar
lorinserbenz
Default Re: does any body know which wire is tachometer signal from ecu or other way....
PIN 62 on the ECU will get the RPM.
Old Aug 24, 2004 | 10:47 PM
toylee's Avatar
toylee
Default Re: Re: does any body know which wire is tachometer signal from ecu or other way....
pin62 do you know what color is it ... or how do i know where pin62 locate it...
Old Aug 25, 2004 | 07:05 AM
SungNamZ's Avatar
SungNamZ
It is Y/R. I am assuming this is Yellow/Red (Stripe). If you go to:
www.vortechsuperchargers.com and then to "Support", you can find on page #11 of the 350Z "Installation Instruction" a the ECU harness.
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
