newbie here
Old Sep 23, 2004 | 10:35 PM
G2FAST's Avatar
G2FAST
Originally posted by RiCeBoI104
what is causing the alignment problem? is there a fix? please explain =(
also what are common G35 coupe problems? if any at all
last but not least. are there any other G35 forums? i'd like to read more into the car but i cant find a good forum (other then this one), please PM me this info
What part of Cali are you from? I haven't heard of anyone that I know having a alignment problem. I have heard some failers in the motors of the windows but not enough people to say its a huge problem.
I did a lot of research on cars when I was in the market and the G35 is a great car and I would buy it again if needed too.
G35Driver.com is a great forum for the G along with FreshAlloy.com. A new site if you would like to join is Infiniti-G35.com
Enjoy!
Old Sep 25, 2004 | 09:19 AM
Babiephat's Avatar
Babiephat
For Technical Service Bulletin, you can go to: http://www.infinitihelp.com/Infiniti...s/G35/Year.htm
I think the Tranny Issue was primarily a 2003 issue along with a lot of 350z... I haven't heard of anybody having issues with the newer '04's... I would just check the TSB for up to date info.
I was choosing between the TL and G35 as well.. but decided to get the couple and got the G. Both are great cars... Drive them both again on the same day back to back, and that might help you with your decision (I did...). Good luck and hope this info helps! I might be a bit biased, but I'd go with the G...
Old Sep 25, 2004 | 10:40 AM
RiCeBoI104's Avatar
RiCeBoI104
thanks for the help.. i'll be checking out those forums.. and if all goes well right now i'll be joining you guys with a 2005 G35 =)
Old Sep 26, 2004 | 12:41 AM
Phizz3l's Avatar
Phizz3l
I just went to a carshow to chill with some buddies... met acouple g owners.... And from what i heard... the 04 have been rock solid, unlike the 03s... so I am probably going to be a G owner... unless for some reason I fall in love with the FX that i will test drive this week
ricks350z
Dec 5, 2012 03:51 PM
EnthuZiast
Sep 7, 2003 02:51 PM
mdrobe2
Jul 14, 2003 07:41 AM
afr0puff
Jul 9, 2003 03:31 PM
lauderdale75
Jan 9, 2003 06:23 PM
