Need pics of coupe w/ H-tech & 20s
Old Sep 22, 2004 | 04:01 PM
moog's Avatar
moog
Default Need pics of coupe w/ H-tech & 20s
Anyone w/ 20's and H-tech's please post pics up.
Old Sep 22, 2004 | 04:36 PM
HaNkYs_Z's Avatar
HaNkYs_Z
dont like your gaps?
Old Sep 22, 2004 | 05:14 PM
G352NV's Avatar
G352NV
Hmm is H the shorter drop or the higher drop? I have the Higher of the two but for a Z.
Attached Thumbnails Need pics of coupe w/ H-tech & 20s-picture-121.jpg
Old Sep 22, 2004 | 07:32 PM
moog's Avatar
moog
G35:
S-tech drops 1.2 front & .9 rear
H-tech drops .6 front & .3 rear
350Z:
S-tech drops .7 front & .6 rear
H-tech drops .3 front & .2 rear
I'm looking for G35 coupes on G35 H-tech springs on 20s
Old Sep 22, 2004 | 08:43 PM
G352NV's Avatar
G352NV
Yep mine are the H for the Z. Im really really happy with them! More so then my eibachs.
Old Sep 23, 2004 | 05:26 AM
moog's Avatar
moog
The spring rates are:
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Stock spring rates are
314/342
So the 350Z H-techs are slightly firmer than the stock spring rates, whereas the G35 H-techs are much softer in the rear. I want that slight drop, but I'm not sure how the much softer springs in the rear will feel. Right now I have about a 2 finger gap all around...how much gap do you have G352NV?
Old Sep 23, 2004 | 08:38 AM
G352NV's Avatar
G352NV
Ill check when I get home.
Old Sep 23, 2004 | 10:10 AM
yonimation's Avatar
yonimation
G352NV
hows the alignment? so your drop is .2 front and .3 rear? did it bring the alignment back to spec?
i want to go with the 350z s tech on my coming g35c, which would be a .6 and .7 drop, was wondering if they can fix the alignment without the camber kit
Old Sep 23, 2004 | 01:24 PM
bwzabodyn's Avatar
bwzabodyn
William, are you more concerned with comfort or performance (or a combination of both)? I would look at the S-techs for the 350Z - they lower you about 3/4 of an inch all the way around and the spring rates are much more performance oriented than any available for the G35 - my favorite are the RS*R's for the 350Z, but they lower about .8" all the way around (advertised at .6") and have more aggressive spring rates... whatever you choose, good luck...
Old Sep 23, 2004 | 05:23 PM
g35thanh's Avatar
g35thanh
just do it!haha
BYBYCOP
Jul 4, 2011 02:11 AM
irishsig
Suspension
Apr 21, 2011 09:24 AM
RCKTDAWG
Jan 27, 2005 02:10 PM
