Anyone Supercharged There G35X?
Old Oct 27, 2004 | 08:03 AM
Blown01GTP's Avatar
Blown01GTP
Default Anyone Supercharged There G35X?
I've been looking at the Coupe but if you can supercharge the AWD version it would make for an even better package.
Old Oct 27, 2004 | 09:57 AM
roydiculous's Avatar
roydiculous
You would hafta be sure the stock drivetrain (transfer case) could handle the extra HP.
Old Oct 28, 2004 | 07:17 AM
learn2turn's Avatar
learn2turn
It can handle it.
However, you are starting off with a heavier, slower, and less F/R balanced than the 2 wheel drive variants.
Old Oct 28, 2004 | 07:49 AM
Gsedan35's Avatar
Gsedan35
Originally posted by learn2turn
It can handle it.
Not that I'm into this whole idea, but just a casual observation and only for the sake of conversation. I picture this, oem coupe sitting on corner scales, G35X also on corner scales. Can we really draw a conclusion that each cars scale numbers would really show all that different to truely impact the entire performance picture in relation to F/R balance. And the differance in weight is only 200lbs between a, a/t coupe and the G35X, with the majority of the AWD equipment down extreamly low (low CG). Now, it's not just the drivetrain that's adding the X's extra weight, it's the fact that the suspension is different, much of weight saving aluminum is ditched in favor of heavier steel parts.
Frankly, I'd rather work the RWD setup then settle for a AWD-a/t-open front diff combo, IMO.
Old Oct 28, 2004 | 07:56 AM
Gsedan35's Avatar
Gsedan35
Default Re: Anyone Supercharged There G35X?
One nagging detail remains unresolved, the X uses a different front suspension. The front sway bar is totally different, no aftermarket sway bars exist for the X for that reason. It also remains a unanswered question if any aftermarket shock or coilover will work on the car in the front either. We have seen one X owner use regular sedan Eibachs to lower his car, still looking to resolve the shock/coilover issue however.
To be fair, on the front sway bar, their is a company that you can sent a oem bar and the oem mounting hardware to and they can make a thicker copy of it.
Old Oct 29, 2004 | 10:38 PM
articfury's Avatar
articfury
Charter Member #55
Gsedan35,
How does the X proportion power between the front wheels with an open-diff?
D
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
