v4 kinetix plenum installed... but bogs during engine crank?
Old Dec 7, 2004 | 01:20 PM
andypandy's Avatar
andypandy
how much is the fee?
Old Dec 7, 2004 | 01:32 PM
teh215's Avatar
teh215
Originally posted by lsdunique
We do however offer
re-gasketing for a very small charge, where we clean off the old gasket, clean in and re-adhere a new gasket.
this requires the plenum to besent back to us for a couple days however
What exactly is a "re-adhere"? Why can't you just either get a new gasket or re-torque the bolts? Also, if you re-torque I would clean the bolts and re-apply the thread locker.
Old Dec 7, 2004 | 02:16 PM
andypandy's Avatar
andypandy
the cork gasket is actually 'glued' onto the plenum.
i went to retorque everything and one bolt snapped in two. great.... seems like my luck with the plenum is down. i'm switching back to the stock plenum... hopefully that will seal down.
thanks for the help guys and lsdunique. this plenum is for sale.
Old Dec 8, 2004 | 08:37 AM
RedHerring's Avatar
RedHerring
I got my v4 last night and it took about 50 minutes and 3 beers to install.
After the three beers wore off, I drove it and the air flow has definitely been freed up. Engine braking is much less, the engine sounds like it isn't having to work as hard in the upper rpm band, but is giving more power. I had to adjust my brace, but no problems. Sounds very good.
You give up too easily. I bet you find the problem when you swap back. Go to pep boys and get some permatex copper gasket maker, apply sparingly around the kinetix seal and reinstall. Rarely does anything go right the first time. Try again, you owe it to yourself and your Z.
Old Dec 8, 2004 | 11:47 AM
andypandy's Avatar
andypandy
ok... one last friggin' try. i will take your, RedHerring's, advice. took me 3 days to alleviate the problems... even visited Jason at Performance Nissan for some info and bought an extra upper plenum gasket. thanks.
Old Dec 8, 2004 | 11:57 AM
ttsupra94's Avatar
ttsupra94
So you got it all fixed? What was the problem?
Old Dec 9, 2004 | 04:05 PM
andypandy's Avatar
andypandy
^ not fixed. no more bov or sci-fi spaceship sounds once car is off... i don't think it's a leak. i have used redherring's silicone gasket idea and i believe the plenum is sealing up really nicely. used it for throttle body too just to be sure.
i called Performance Nissan service and they say a leak within the plenum/intake will cause a higher idle. my idles are fine... very smooth and at nominal rpms (600~700). car cranks fine during the cold too.
service tells me it has something to do with the fuel... which may explain the stall during warm cranks. in any case, taking the car in for diagnostics tomorrow and getting this PITA fixed.
thanks all for the help.
happy and safe motoring.
Old Dec 9, 2004 | 04:53 PM
lsdunique's Avatar
lsdunique
I am glad to hear you are getting cloer to the solution. It didnt sound like a leak problem from your description
Old Dec 10, 2004 | 04:35 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Well i tightened all my bolts down again, and i never had the problem after. I only had the warm engine, no start issue once, but never had any issues with driveability then or now. Reset your ecu after tightening all the bolts down. It may be a kinked vaccum line that runs into the plenum at the back.
good luck with it.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
