Nismo Intake Install Question
Old Dec 19, 2004 | 11:03 AM
afro561's Avatar
afro561
Default Nismo Intake Install Question
Is the wheel well cover permanently removed in this install?
Old Dec 19, 2004 | 11:45 AM
Speedracer's Avatar
Speedracer
Default Re: Nismo Intake Install Question
Absolutely not. The intake cone sits in the space between the wheel well cover and the front bumper. Here is a pic (not great quality, sorry) that shows the cone from the Nismo intake with front bumper removed. You can easily see how it all fits together.
Old Dec 20, 2004 | 09:25 AM
King Tut's Avatar
King Tut
When I installed mine it was very close to the fender liner. Just adjust the pipes some more and it will fit.
Old Dec 20, 2004 | 09:54 PM
jreiter's Avatar
jreiter
Like folks said above, you keep the fender liner. You need to temporarily remove it while installing the filter, but you put it back on afterwards. I was actually able to simply undo many of the screws on the liner and carefully pull back on it far enough to get the filter in. Never had to fully remove the liner.
Old Dec 21, 2004 | 12:01 PM
afro561's Avatar
afro561
Yea, the last part of adjusting the pipes was the hardest but thanks for your replies. Im gonna finish this up on Wed.
Old Dec 22, 2004 | 08:05 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
just need to remove the few bottom screws / clips from the fender well... you can do it without removing the wheel if you cut it all the way to the left (depending on your wheel . tire size...
JjL
East Canada
Jun 12, 2019 03:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
_koubie_
Sep 20, 2015 06:34 PM
