exhaust leaking
Old Dec 22, 2004 | 09:35 PM
zukbang's Avatar
zukbang
Default exhaust leaking
how can i tell if my exhaust is leaking?
i have borla and kinda scared it might leak
thanks
Old Dec 23, 2004 | 08:27 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
you can get under the car, and check all the bolts first, to make sure that they are all tight. Make sure the gaskets are ok too, you can spray some soapy water on the flanges, and start the car up, and see if there are any leaks. if there are, the water will bubble at the flange, and you can tell that way. But you will have to do this when the exhaust is cool, otherwise the water will just boil off etc....
or you can just take it to an exhaust shop like a speedway muffler or midas etc... and they can test the exhast for you.
but basically, just make sure the bolts are all tightened up.
if you start to hear sputtering coming from under the car, (not a sound the exhaust makes that you just happen to hear, but actual noise coming from directly under you), then you may have a leak.
Old Dec 23, 2004 | 08:35 AM
blascelles's Avatar
blascelles
You might be able to see a carbon build up around the flange as well.
Old Dec 23, 2004 | 11:41 AM
zukbang's Avatar
zukbang
cool..thanks
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Justin100
Nov 29, 2015 03:58 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Li1ag
Sep 28, 2015 02:07 PM
