SES light after kinetix v2 install.
Old Jan 9, 2005 | 04:33 PM
Dissolved's Avatar
Dissolved
Default SES light after kinetix v2 install.
Do I need to reset my ecu? If so, which method? Technosquare's method or should I disconnect battery?
thanks
Old Jan 9, 2005 | 05:40 PM
imalazeeass's Avatar
imalazeeass
first of all, i would return the v2 for a v4. And easiest way to reset is the disconnection of ur battery. good luck.
Old Jan 9, 2005 | 05:57 PM
Dissolved's Avatar
Dissolved
v4s are cracking too. Plus I bought this used
Old Jan 9, 2005 | 09:28 PM
all_bark's Avatar
all_bark
no they are not, not that I have heard.
so I guess you got your stalling issue solved. what was the problem????
Old Jan 9, 2005 | 11:44 PM
imalazeeass
I heard that the v2 will eventually give you problems in the long run and that it is actually dangerous to use it. You should look up threads regarding this issue. You should also contact Kinetix since they might give you a replacement for free as long as you have the information of the person you purchased it from.
blasian
Oct 3, 2007 05:22 AM
HockeyZ39
Jul 3, 2006 11:48 PM
BOZ23
Apr 3, 2006 02:45 PM
Zivman
Feb 7, 2005 08:46 AM
Nforce1
Oct 3, 2004 09:06 AM
