Kinetix test pipes w/out reflash?
Old Jan 21, 2005 | 04:56 PM
pearlZ's Avatar
pearlZ
Default Kinetix test pipes w/out reflash?
As of now, I have the popcharger and nismo exhaust. I want to finish off the flow with the resonated pipes, but do not plan on resetting the ecu.
I have seen some with this set up run pretty lean, likewise others that run normal (ie. Zboater). Help...
Thanks guys and girls
Old Jan 21, 2005 | 05:05 PM
westpak's Avatar
westpak
SFZCC
All are different, I had Intake/Plenum/Test pipes/y-pipe/exhaust with no reflash and had an AF of 13-13.5
So I would go ahead and do mods then dyno and see what you end up with before you reflash.
Old Jan 21, 2005 | 08:56 PM
pearlZ's Avatar
pearlZ
Thanks for the reply! I thought it might be different from car to car. How long did you wait after doing your breather mods to dyno. If you wait longer does it give the ECU time to adjust on its own somewhat?
Anyone else have any experiences with running lean/or not after three or four intake/exhaust mods?
Old Jan 22, 2005 | 03:58 AM
westpak's Avatar
westpak
SFZCC
I did a dyno after a while of doing most of them but right after the test pipes, which leaned the car out, I was at 12.5 before that, but I did another one a few months later and not much change.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
