Cam/Header install?
Old Jan 21, 2005 | 09:38 PM
done12many2's Avatar
done12many2
Question Cam/Header install?
For those of you with cams. Did your installers remove the heads or did they put the cams in without removing the heads.
If the heads are removed, can headers go in from the top saving money by installing both the cams and headers at the same time?
I am doing both of these mods in the immediate future and am trying to find the best route as far as install is concerned.
Old Jan 22, 2005 | 12:47 AM
scz's Avatar
scz
Default Re: Cam/Header install?
You dont have to remove the heads, and you can install headers easier with all of the coolant lines removed as they would do with a cam install.
Old Jan 24, 2005 | 09:48 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
That's correct. You do not remove the heads, and it is much easier to do the headers at that time. If you remove the heads, it would be much more trouble than it's worth.
Old Jan 24, 2005 | 01:04 PM
King Tut's Avatar
King Tut
No need to remove the heads unless you are tossing in some new valves to go along with those cams. Normally even the valve springs and retainers can be done without taking off the heads.
Old Jan 30, 2005 | 11:18 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
no need to remove heads...
but our KITCAM is a must!
http://performancenissanparts.com/ca...oducts_id=1809
Old Jan 30, 2005 | 02:02 PM
___DJK___'s Avatar
___DJK___
Jason, how much would Performance charge to install crawford headers and nismo or jwt cams? (at the same time)
Old Jan 30, 2005 | 05:39 PM
Jason@Performance
Performance Nissan
header install is drastically reduced when installing the parts...
i have my install guide in the office ill check back in this thread tommorow... or tony will..
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
