$95 Test Pipes Installed...
Old Feb 4, 2005 | 04:04 PM
350zOnJuice's Avatar
350zOnJuice
Default $95 Test Pipes Installed...
Sorry for the blurry pic , Installed them today , I also have the Borla TD.
Sounds Great.. A bit rasp at high rpm but deep growl on idle and low rpms.
Old Feb 4, 2005 | 08:13 PM
Jaki's Avatar
Jaki
Looks very nice, how's the performace?
Old Feb 4, 2005 | 08:21 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Ditto, and any sound clips?
Old Feb 4, 2005 | 09:42 PM
SH1FT-Z's Avatar
SH1FT-Z
Yeah, what they said.......
Old Feb 4, 2005 | 11:04 PM
FairladyZ's Avatar
FairladyZ
Looks hott! Great buy! Those actually look alot better in your pics than the one pic the guy is using to sell them on ebay.
Old Feb 5, 2005 | 03:10 AM
350zOnJuice
Man , they sound great... keep in mind i also have the borla TD im going to try to post some clips
thanks guys
Old Feb 5, 2005 | 08:39 AM
002-M-P's Avatar
002-M-P
Did you get those from DeluboZ on ebay. I got a set of his Testpipes and am very happy with them. Seem to be very well made and extremely affordable.
Old Feb 5, 2005 | 09:54 AM
copba1t's Avatar
copba1t
Different part, these are resonated.
Old Feb 5, 2005 | 09:57 AM
002-M-P's Avatar
002-M-P
Yeah, i knew that. I was just comment on how well made his test pipes are, nonresonated and resonated. I have the non-resonated ones.
Old Feb 5, 2005 | 10:17 AM
westpak's Avatar
westpak
SFZCC
You will probably have some raspiness as the resonator is smaller and in a different location, but for that price you can't beat it.
How is the sound? I found mine got so quiet with the turbos that the resonators were probably not needed.
Old Feb 5, 2005 | 12:11 PM
002-M-P's Avatar
002-M-P
Yes I agree. It is very very quiet with turbos. I think it is quieter than stock when not under full boost. I should be getting The DeluboZ Ypipe and either the Topspeed exhaust or make a custom single one. That should solve my really quiet problem.
Old Feb 25, 2005 | 11:06 AM
[]D[][]V[][]D's Avatar
[]D[][]V[][]D
How are these working out for you bro? Are you still in love or are you gonna spring for some HF cats?
Old Feb 25, 2005 | 01:49 PM
veilside350zTT's Avatar
veilside350zTT
Default test pipes
so where did you get ur test pipes at? and how much?
also why did u go non-resonated?
thanks appreciate it
Old Feb 25, 2005 | 02:04 PM
[]D[][]V[][]D
Veil, those res pipes are from Megan Racing.
if you go on ebay, search: "g35 pipes".
But these are resonated.
I have a set sitting in my garage, I just wanted to see how they were holding up for 350juice.
Old Feb 26, 2005 | 06:48 PM
veilside350zTT
Default megan racing
So whats difference between resonated and not??
HP??
Loudness??
Old Feb 28, 2005 | 06:52 AM
rocketrider's Avatar
rocketrider
I had mine installed on Friday. It sounded great. There was not rasp or CEL (I have a 2003). My Borla true dual cat back had been squeeking a little in the rear where the hanger was rubbing against the aluminum mount (where the rubber boot is). With the test pipes, that squeeking turned into a major rumble. I also experienced a "whisp" sound around the H pipe of the exhaust at around 2200rpms. I would rev it up to 3000 and let off and at 2200 I heard what sounded like something rattling around inside the pipe. So after $45 to install (I got a deal), there were still vibration problems so I took it to a muffler shop. I had read on here that some people had brackets welded to the pipes and mounted them to the arm that is bolted into the transmission. That didn't fix the "whisp" problem however. So then we started removing the exhaust from the test pipes back. We found nothing in the pipes. Then we cranked up the car with the exhaust disconnected and still heard the "whisp." It turns out that there's something (metal shavings, ect.) inside the resonator of the test pipe that's rattling around. It cost me another $50 at the muffler shop to determine that. I did get the rumble fixed by cutting the hanger of the pasenger side muffler inlet and welding it back on at an angle. So now I have over $200 in these pipes and I still have that rattling inside the resonators. Does anyone know if whatever's in there will eventually wear down enough to blow out? I plan to complain to Megan Racing but even if they did send a replacement set, I'd have to pay for shipping and labor to put the new ones on.
Old Feb 28, 2005 | 09:36 AM
veilside350zTT
Default non-resonated
sounds like you should have just got non-resonated. would have been less hassle
Old Feb 28, 2005 | 11:56 AM
[]D[][]V[][]D
These pipes are garbage!
My car sounds like a total s hit box now.
At idle and under 2500rpms, it sounds fine but as soon as you get past that my car sounds like a rattle snake inside a tin can.
The gains are so minimal that I don't think it's worth riding around with these things.
Old Feb 28, 2005 | 12:26 PM
veilside350zTT
HEY MAN U SAID URS SOUNDS LIKE GARBAGE BUT THE GUY THAT STARTED THIS THREAD SAID HIS SOUNDED GOOD. SO I WAS JUST WONDERING WHATS UP? do you guys have the exact same thing or what?
Old Feb 28, 2005 | 01:03 PM
[]D[][]V[][]D
If 350onjuice has the megan racing ones, he's having better luck than me.
