AAM plenum spacer installation problem
Old Mar 4, 2005 | 08:16 AM
S350Z's Avatar
S350Z
Default AAM plenum spacer installation problem
Has anyone tried to install the spacer. I tried to install my spacer last night but it seems the bolts that came with the spacer are too short and I can not fit the strut bar to where it wont hit the enigne or it the hood. I tried for three hours yesterday with my nissan tech. Thanks.
Old Mar 4, 2005 | 08:37 AM
Zivman's Avatar
Zivman
Default Re: AAM plenum spacer installation problem
i found your problem -
You were working with a nissan tech!
In all honesty, what size is the spacer?
Old Mar 4, 2005 | 08:50 AM
S350Z's Avatar
S350Z
I havent mesaured the spacer yet but I think its half an inch in the front. Actually the nissan tech is really good and he knows what he's doing and I think he came from performance nissan.
Old Mar 4, 2005 | 09:18 AM
DrVolkl's Avatar
DrVolkl
Are you supposed to use the strut bar with this spacer?
Have you tried sticking some washers under the stut bar bolts to perhaps make it fit right?
Which bolts are too short?
Old Mar 4, 2005 | 09:31 AM
S350Z's Avatar
S350Z
Yes I tried sticking some washers as instructed for the strut bar but it either hits the engine or the hood. I even tried adjusting the strut bar itself. It looks ok when you start the engine and rev it but when your driving you get alot vibrations in the cabin which means it hitting the strut bar. Actually there are marks on the plenum where the strut bar hits the plenum. The bolts for the top of the plenum are too short.
Old Mar 4, 2005 | 10:18 AM
Sins4u33's Avatar
Sins4u33
i think we just talked to you on the phone, gave you the wrong bolt size. its M6X1X70 and 55. or you can use the longer bolts for the front and buy a set for the rear.
Ben
Old Mar 4, 2005 | 10:19 AM
S350Z's Avatar
S350Z
Thanks I'll try that.
Old Mar 4, 2005 | 10:24 AM
DrVolkl's Avatar
DrVolkl
It wouldn't suprise me that it hits...the reason why you need a new strut bar for the crawford is that there just isn't enough room between the plenum and the hood....this is way the thing is sloped in the first place....adding the spacer "squares" it off and really makes for a tight fit.
Every car's specs are a little different...your hood might sit a little low, or your engine a little high (talking mm here) and it just might be enough to cause a problem.
If use more washers and remove the hood insulation, will that help??
Other option is buying a crawford strut bar (I know, more $$ and not why you bought the spacer in the first place). Perhaps a stillen engine dampner will take some movement out of the engine when it revs...that could help too.
As for the bolts, they might have sent you the wrong ones....
The other possibility is that you're doing something completely wrong, but it's hard to know without being there in person. Sounds like you're problem shooting everything pretty well.
Old Mar 4, 2005 | 10:30 AM
S350Z's Avatar
S350Z
Just talked to AAM it seems that they didnt send me the right bolts. Yeah I even tried the stillen engine dampner but it still hits. They also informed me that it ok that the strut bar touches the rubber piiece on the hood but it seems that on my car that it touches alot. So I guess I'll try playing with the strut bar alittle more and hope it works.
Old Mar 4, 2005 | 10:33 AM
S350Z's Avatar
S350Z
Yeah I even tried to take the rubber pieces out of the hood to see if that worked but same results.
Old Mar 4, 2005 | 11:04 AM
jeffw's Avatar
jeffw
Did everyone get the wrong bolts? (I haven't tried to install mine yet).
Jeff
Old Mar 5, 2005 | 06:49 AM
ZinMiami's Avatar
ZinMiami
Old Mar 6, 2005 | 06:32 AM
TX-Ruben's Avatar
TX-Ruben
With all 3 washers on every mounting point, the strut bar started really close the engine, but a little tweaking, it clears everything now.
Did you start with all 3 washers? I think thats a must as it was REALLY close and started off touching with just 2.
Old Mar 13, 2005 | 06:24 AM
alininger2001's Avatar
alininger2001
I only had to put 2 washers under all the mounting points in mine, the engine is close to the bar but not much closer than it used to be. With three washers, the hood buckled up.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Stevo Z
Oct 3, 2015 09:14 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
