Cheap and effective (ypipe <-> stock bpipe) mating
If you've got a 3" aftermarket ypipe bolted to the 2.5" stock exhaust, consider this very simple fix that will most certainly reduce turbulence and power loss, and also clean up the sound a bit:
http://g35driver.com/forums/showthread.php?t=41690
I know this is not a new idea, but bailyrx on g35driver did some homework and found quality sources for the parts and labor. I did this fix and it turned out great. After my welder was done he showed me the old bpipe flange and there was a 1/4" black ring around it where the exhaust was slamming into it. Not good.
thanx for this post. i have the ut ypipe and stock bpipe, too. when ordering the flange, does one need to know the distance btwn the bolt holes, or is it standard for a 3" ypipe?
ps: sorry i called you "cobalt" earlier; that's just what my eyes saw at first.
Heh I didn't even notice the name thing. I go by copbait on the G forum but that name was already taken here. I had to go with copba1t on the plate I just ordered as well. Those Bhastids!
thanx. i'll call him tomorrow. i'm thinking this mismatch might be contributing to the rasp i'm hearing.
Justin100
Nov 29, 2015 03:58 PM
