AAM Spec Product Release: Cat and Y Pipe !Dynos!
Old Apr 14, 2005 | 12:20 PM
dynamic6er's Avatar
dynamic6er
Default AAM Spec Product Release: Cat and Y Pipe !Dynos!
Product Release!
AAM is proud to announce the release of several exciting exhaust products for the Nissan 350Z and Infinity G35.
AAM Spec Y-Pipe: $499
AAM is proud to announce the release of its Y-Pipe for the Nissan 350Z and Infinity G35. Constructed of 16-gauge T-304 Stainless Steel to ensure the highest reliability, quality, and performance. Using smooth 2.5" mandrel bent tubing and stainless steel flex joints which flow into one large 3" tube, the AAM Spec Y-Pipe improves upon the factory Y-Pipe's restrictive design by allowing a substantial increase in the mass of exhaust flow, and reduces the backpressure and thremal stress, which helps to unleash the engine's potential for increased power and torque.
Dyno tested on a near stock 2004 Nissan 350Z, the AAM Spec Y-Pipe gained 8 RWHP in comparison to the factory Y-Pipe!
Don't be fooled by competitiors designs which commonly use 18 or 20-gauge tubing that is prone to cracking, and non-stainless steel (if any) flex sections. The AAM Spec Y-Pipe is a direct bolt-on upgrade that requires no modificiation of any factory components.
AAM Spec Cat Pipe (off-road use only!): $249
The highly anticipated AAM Spec Cat Pipes for the Nissan 350Z and Infinity G35 are finally here! After servicing and installing several of our competitors designs we decided to make a higher-quality cat pipe that meets the demanding reliabilty expectations of our customers. In addition to having poor fittment, many of the cat-pipes on the market are constructed of thinner, lower grade stainless tubing. Not only are these units highly succeptable to fatigue and cracking on near stock 350Z's and G35's, some customers with supercharged and turbocharged 350Z's have torn apart the weld joints of these inferior cat-pipes. Made out of 2.5" mandrel bent 16-gauge 304 stainless steel to ensure the hightest reliability and quality, the AAM Spec Cat Pipe replaces your vehicles restrictive factory catalitic converters to allow the higest possible exhaust flow.
Dyno testing has shown 8 to 10 RWHP gains on a near stock Nissan 350Z and 20+hp gains on a turbocharged Nissan 350Z!
The AAM Spec Cat-Pipes are for off-road use only and are a direct bolt-on replacement of the factory cats.
Dyno Comparision Stock to AAM Y-Pipe and Cat-Delete Combo
We now also have a dedicated AAM Spec ecu flash for our Angled Plenum Spacer, Cat-Delete Pipe, and Y-Pipe Combo.
Dyno Comparision of AAM Spec Stage I Performance Package with/without AAM Spec ECU Reflash
ECU Flashes for '03 and '04 (most): $595
*all dyno runs perfromed on a '04 with AAM Spec Angled Plenum Spacer and JWT Pop-Charger.
Please feel free to call or email
Altered Atmosphere Motorsports
8011 Cessna Ave
Gaithersburg, MD 20879
301.330.8835
sales@alteredatmosphere.com
www.alteredatmosphere.com
Old Apr 14, 2005 | 12:54 PM
jkoc's Avatar
jkoc
superb
Old Apr 14, 2005 | 01:35 PM
Sins4u33's Avatar
Sins4u33
mmmhmmm gotta love those mandrel bent pipes...i run the test pipes right now and wow...do these things open up the exhaust system...it just screams from 3-4k rpms!
Ben Y
AAM
Old Apr 14, 2005 | 04:30 PM
NA&CH's Avatar
NA&CH
Groub buy in future?? Looks very nice.
Old Apr 14, 2005 | 06:04 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Why on the reflashed dyno do you guys run rich and lean it out up top? Wouldnt you see better gains with a 13.1 a/f across the board? Also does your reflash incluse a raised rev limit? Do you guys touch timing? You guys didnt rev past stock in those dynos. Nice y-pipe BTW....
Old Apr 14, 2005 | 08:58 PM
xswl0931's Avatar
xswl0931
Note, it's spelled Infiniti
Old Apr 14, 2005 | 10:38 PM
Secret Z's Avatar
Secret Z
Are these test pipes resonated or non-resonated?
Old Apr 15, 2005 | 12:00 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Old Apr 15, 2005 | 04:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Looks non-resonated to me...
Old Apr 16, 2005 | 07:02 PM
Solrac's Avatar
Solrac
They're non-resonated. I had these put on my car, and wow.. They do sound nice! You can definately feel the difference in power increase.
Old Apr 17, 2005 | 11:53 AM
yacoub's Avatar
yacoub
What's up with your first dyno plots not crossing at 5252rpm?
Also, I'm surprised to see an 11ft-lb torque gain from just a y-pipe, especially when you're losing back pressure. That's pretty impressive if it's legit, and would justify the pricing for me. =)
Old Apr 17, 2005 | 12:15 PM
GQ 350z's Avatar
GQ 350z
AAM, any chance of another GB on the AAM spacer? I can help out if you like.
ravi
Old Apr 18, 2005 | 12:27 PM
Sins4u33's Avatar
Sins4u33
Bump
If your interested in the y-pipe or test pipes let me or dave know
Ben Y
AAM
Old Apr 18, 2005 | 01:53 PM
dynamic6er's Avatar
dynamic6er
That's strange. I did not see that. Most likely its the scale is wrong on the chart and I need to change. I'll take a look and see what's up with the dyno computer.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
