AAM spacer instructions kind of suck -- or else i suck
guys i'm pre-reading the aam instructions for the spacer. not well written imo.
questions:
1. i was supplied M10 30mm (6) bolts. the instructions say i should have 4. no where in the steps does it say where to actually use the 4 (or 6). tips?
2. i was told from AAM to buy M6 70mm (3) bolts. instructions dont mention this. no where in the steps does it say where to use it. tips?
3. steps 15-20: what the? can someone clarify what i'm actually achieving? whre are the washers that it mentions in step 17? do i have to buy this? iis this where i'm supposed to use the supplied 24 spacers?
any help would be appreciated.... i suppose i should just go in and open up the car and DO it but i always prefer just reading and understanding everything before doing.....
questions:
I agree they are not written well. I noticed you were in this thread but may have missed my last few posts, since I just installed it last night:
https://my350z.com/forum/showthread....&page=26&pp=20
with the help of a local Z enthusiast, i was able to delineate the crude instructions.
i had massive leaking issues with the center 6 bolts... i tightened them all to within the in/lb specs... but still leaked.. i resolved it by turning on the engine, and hand-tightening them disregarding the specs heh... now the car purrs smooth and idle is solid.
it is weird, the instructions make NO mention of the fact that with the spacer, you will NOT be able to screw in the two nuts for the two studs on coming from the lower plenum. is this ok? (ie: i'm talking about the two studs that have the torx top). am i supposed to buy my own longer ones? what the heck?
right now theyre just there. i didnt bother removing it. i just used them to guide me when installing the spacer and gasket.
also, i torqued everything to within spec, except the middle bolt of the lower half of the group of bolts numbered 1 through 6. ( i cant recall the bolt number). that lower half middle bolt required a lot more tightening than any other bolt. i was pissing my pants each turn to fix the leak. i just read in another posting here that people have fixed this problem by replacing the cheap *** o-ring integrated washer with a full rubber one....
anyway, i'm really happy with this mod.... incredible piece.
Freakin sweet, thanks for that. Interesting how the Z makes more and more power as you dyno it. Is this the ecu at work? What are your driving impressions?
I wish AAM would address another group buy..I've posted like three times with not even an acknowledgement =(
ravi
ravi
Originally Posted by xziteme
Here's my dyno results of before & after plenum spacer install.
Do you think my lack of a catback exhaust could be the culprit? Maybe it's bottlenecking me at higher rpm?
may i ask where are "your" instructions 350zenophile?
http://www.alteredatmosphere.com/ang...structions.doc
Originally Posted by mikedZ33
Heres your updated instructions, if you would have done a search you could have found it too.
