successful 05' w/ TestPipes anyone?????
Old May 11, 2005 | 02:38 PM
DIE DIE's Avatar
DIE DIE
Default successful 05' w/ TestPipes anyone?????
Well guys I've heard the 03'-05's ECU's react differently to mods.. I had helix TP, but I got a CEL.. I'd like to try some different testpipes, but I want to make sure there are other 05's out there currently using them with no problems first...I wan't something semi cheap, but also resonated..
Helix is out unless they have something resonated....
Everyone says the kinetix don't fit right...
Stillen are not resonated + pricey...
Megan racing is a joke....
Crawford is too much $$$ period....
any opinions????!??
Old May 11, 2005 | 06:44 PM
DIE DIE's Avatar
DIE DIE
this **** ain't leavin the top without some answers
Old May 11, 2005 | 09:33 PM
Z BOY's Avatar
Z BOY
sup ry. actually, the kinetix res tp i ran were very easy to install, with absolutely no rubbing problems. its their hfc that rub cuz they're much fatter. as to whether or not they will throw a cel on the 05, i can't say. i read recently that the 05s have a wideband sensing setup vs narrow for the older models, which should make things more sensitive. i KNEW you wouldn't be happy with the stock cats for long!
Old May 12, 2005 | 05:33 AM
Zivman's Avatar
Zivman
hey bud - all you need are two packs of nonfoulers to get rid of the SES that you WILL get with an 05.
HELP! Spark plug non fouler. Part 42002 for 3.99 from autozone.
They are a 2 pack. Get two packs and drill 2 of the nonfoulers out with a 1/2" drill bit. screw the NON driilled nonfouler into the test pipe. Then screw the DRILLED nonfouler into the non drilled fouler - install your o2 sensor into that. You will be SES light free and it will cost you less than $10 and about 1/2 hour of time.
LINK with pics
Old May 12, 2005 | 12:09 PM
DIE DIE's Avatar
DIE DIE
^zivman- thanks for the info.. I'm trying to lean away from that tho..I want something that I can just throw on with no probs no fittment issues and no cel... (and no rasp I WISH haha)
matt- I'm check ur PM's..
anyone else have any info???? Anyone tried kinetix on the 05' yet??
Old May 12, 2005 | 12:50 PM
Zivman's Avatar
Zivman
If you run the HELP! method, you won't have any fitment issues or CEL, the easiest and most tested way to get rid of SES light.
Old May 12, 2005 | 01:28 PM
DIE DIE's Avatar
DIE DIE
yeah I guess you're right..since I can't be certain that the resonated TP won't throw a cell, I might as well not spend the extra ca$h.. Now I'm thinking I shoulda just kept my helix and done this
Old May 12, 2005 | 02:45 PM
mikz350's Avatar
mikz350
hey die ide remember my tred?
ive reset my ecu yesterday and no more ses for nownow the car pull faster for sure but maybe it has to do whit the weather
Old May 12, 2005 | 03:07 PM
DIE DIE's Avatar
DIE DIE
it'll come back on if it came on before When I had the Helix TP I tried the same thing...I instaleld them.. no CEl for 2-3 days.. I'm pretty happy except rasp..then the CEL comes on and I'm pissed...wishing I never boought them....then I reset my ECU and it stays off for a few days (got me all excited) only to come back every time
Old May 12, 2005 | 04:20 PM
05 NISMO's Avatar
05 NISMO
would it also would if i were to get the part number 42000, seem like thats the only pack i could find.... i think it might be alittle bit smaller, but let me know. thanks.
Old May 12, 2005 | 06:39 PM
RA11325's Avatar
RA11325
I have the stillens, they are raspy as hell and throw a CEL so cross those off the list , forunately i already built my HELP method device and im gonna install it next week when the rest of my exhaust gets here
Old May 12, 2005 | 07:21 PM
Zivman's Avatar
Zivman
42002 or 42009 will work. Any others won't be the correct size.
You need to make sure you only drill ONE of the nonfoulers on each bank; the outer nonfouler that the o2 sensors screws into. If you drill both nonfoulers on each bank it won't work.
Old May 24, 2005 | 02:18 PM
BostonZ's Avatar
BostonZ
Hey, I've got an '05, and just recently installed the Kinetix TP's. And Yep, I've got the CEL 2 days later!! Won't go away. I think I'm just gonna go with some HF cats.
Old May 24, 2005 | 02:36 PM
Zexy's Avatar
Zexy
So what does this fix do exactly?? Is the bung farther from the cats??
Old May 24, 2005 | 03:55 PM
Zivman's Avatar
Zivman
If you have cats, you don't need the fix. The HELP! method basically gives the o2 sensor a "cleaner" pocket to read from as it moves it out of the direct path of the exhaust when using test pipes.
Old May 24, 2005 | 03:56 PM
Zivman's Avatar
Zivman
If you install the nonfoulers, the CEL will go away. VERY EASY INSTALL - MUCH easier than uninstalling the test pipes and installing HFCs
Old May 24, 2005 | 05:25 PM
BostonZ's Avatar
BostonZ
I'll look into it, thanks a lot!
Old May 24, 2005 | 05:42 PM
Zexy's Avatar
Zexy
So basically it can give innacurate A/F readings? Won't thins aftect hot the ECU plays?
Old May 25, 2005 | 12:58 AM
TunaRollZ's Avatar
TunaRollZ
my 05 with test pipes threw the SES every 300 miles or so. And yes...they are raspy as ****...i hate em. lol
Old May 25, 2005 | 04:01 AM
Zivman's Avatar
Zivman
