05 Track with Crawford Plenum Dyno!
Old May 12, 2005 | 02:28 PM
dan-14's Avatar
dan-14
Originally Posted by thawk408
Ive got 3200 miles right now. Im trying to decide reather to go FI or put in 11.5:1 pistons and go all out NA. I am very interested to see how much power this engine will produce NA.
lol,you and i should have a contest to see who can make more HP with the same mods . i have an 05 track too and i'm trying to decide between building the motor or going with a supercharger.
so far i have the jwt popcharger and nismo exhaust. i'm thinking about ordering the plenum right now .
btw: i recomend the popcharger, but i think it fits differently on our engines. i had to mess with the heat sheild a little.i also had to reshape the metal support peice and put a 1 inch bushing under it where it bolts to the engine bay to get it to fit.
Old May 12, 2005 | 02:45 PM
thawk408's Avatar
thawk408
Could you feel any different with the pop-charger? I am debating weather or not to get it.
Old May 12, 2005 | 02:46 PM
thawk408's Avatar
thawk408
Originally Posted by nis350ztt
Crawford already broke 300rwhp. But I bet 300HP motors will hit it slightly easier.
They have not broken the mark....YET. It will be soon I believe.
Old May 12, 2005 | 03:18 PM
dan-14's Avatar
dan-14
i have to say, the car did seem to pull slightly better. if this is true or if it's all in my head, i don't know .
but it does sound good at WOT and doesn't cost alot
i'd recomend it
Old May 12, 2005 | 06:35 PM
RA11325's Avatar
RA11325
The pop-charger is worth it for the sound alone, it sounds nuts at WOT
Old May 12, 2005 | 07:54 PM
thawk408's Avatar
thawk408
Sort-of off topic, when will you be taking it to the 1/4 mile track? or will you?
I might take it in the future. I am not the best drag racer, so I might need some time to practice.
Old May 12, 2005 | 09:34 PM
Nano's Avatar
Nano
E.T. depends mainly on your skill and can vary a lot if you have no experience
MPH depends mainly on your car and should be more or less constant
MPH is real indicator of power
with 260rwhp you should trap at 104-105mph easy whatever your E.T.
Old May 12, 2005 | 09:43 PM
Z350Lover's Avatar
Z350Lover
Go N/A man... would like to see something different!!!
cheers,
richie
Old May 12, 2005 | 10:38 PM
thawk408's Avatar
thawk408
cheers,
richie
I would also like to see an NA beast. If I did so, I would want higher CR, cams, 8k redline, ITBs, all bolt-ons, and a standalone. Would like to see 400 crank...if not more.
Old May 12, 2005 | 11:05 PM
kosmic's Avatar
kosmic
Damn, that would be crazy. From what I've read, you'll need to beef up your fuel system to take it that far.
Old May 12, 2005 | 11:09 PM
thawk408's Avatar
thawk408
And injectors and fuel pump.
Old May 13, 2005 | 08:36 AM
dougrace zs's Avatar
dougrace zs
We were happy to see the outstanding dyno results from our Crawford Z Performance Plenum on a stock ‘05 Track Z. The ’05 lower plenum (with shorter intake runners than the earlier cars) sure didn't help at all when I installed and dynoed one on my ‘04. We lost power and torque throughout the rpm range. I thought all along that we would loose torque down low with the shorter runners, but was hoping to see some gains up top, which did not happen.
The variable exhaust cam timing on the ‘05 is really helping this engine make power with the shorter lower plenum runners.
This ‘05 dyno shows that he’s making about the same power as ‘03 and ‘04 cars with our whole package (plenum, headers and cats).
I can't wait to see what this thing will do with the headers and cats.
Doug
Old May 14, 2005 | 10:28 AM
Armitage's Avatar
Armitage
:giddywithanticipation:
I wonder if 350whp NA would be possible with this engine with a full NA buildup.
Old May 14, 2005 | 10:30 AM
GQ 350z's Avatar
GQ 350z
Thats a bit optimistic. 300 whp I see though.
Old May 14, 2005 | 10:34 AM
Armitage's Avatar
Armitage
Yeah, I was about to go change it to maybe 310-320 whp. I thought about it and I was like 100whp from NA stuff is too much.
Old May 14, 2005 | 01:17 PM
thawk408's Avatar
thawk408
I think that will all the parts I listed above this engine might put out 400 crank or maybe a tad more.
Old May 14, 2005 | 01:56 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Wow, that's impressive. I know a few people who have dynoed their 287hp Z with both the crawford and the 05 track plenum, and they using both didn't help much. pretty much you would want one or the other.
I guess that the head desings, variable timing, etc.. add up to a good combo when using the crawford on the acutal 05 Z. I guess those differences between the engine really show you how the power is made between the two engines, and how they differ when it comes to modding them. Looks like there will be thing to do to the 05 that don't really work well for the prior years.....
Well, congrats non-the-less!
Old May 14, 2005 | 02:35 PM
  #38
Nano's Avatar
Nano
400 crank is 115hp/liter
there are way better engines that do not produce anything close to that out there. I would be extremely impressed if anyone manages 105/liter, which is about 365 crank... and it remains to be seen if the car will be driveable on the street.
Old May 14, 2005 | 03:37 PM
  #39
thawk408's Avatar
thawk408
In the next few weeks I will be getting the Crawford headers and highflow cats. After I dyno with those it should give us a very good understanding to how well this engine will do NA.
Old May 15, 2005 | 06:42 AM
  #40
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
It's very possible, but it would be very expensive. We're talking sheet metal intake manifold, new valvetrain and agressive cams, good headwork, higher compression pistons, full exhaust, and an standalone to tune it perfectly. With an 8000-8200rpm rev-limiter on a set-up like this it's defintely attainable.
