throaty rasp from exhaust greddy evo II
Old Jun 13, 2005 | 09:48 PM
glogan's Avatar
glogan
Default throaty rasp from exhaust greddy evo II
just installed the stainless steel greddy evo II /w test pipes and I get a throaty rasp at 3500-4000 rpm, anyone know a fix for this? I took it to a muffler shop and they sad to ask greddy if it was a factory defect. It's mainly coming from the y pipes. anyone else have a greddy that might have the same problem?
Thanks
Old Jun 13, 2005 | 10:22 PM
uplz4588's Avatar
uplz4588
its from your testpipes
Old Jun 14, 2005 | 05:58 AM
g356gear's Avatar
g356gear
agreed.....my evo II is perfect but once the test pipes go on it gets raspy. When I look at the angle of the flanges where they attach between the y-pipe and test pipe....they never match. I have had 3 manufacturers now and they all have the same problem. You almost need thick gaskets that deform when they are tightened to compensate for uneven flange angles. The rasp is the resonance of the exhaust gases leaking through the metal gasket and vibrating. PIA!!
Old Jun 14, 2005 | 08:06 AM
glogan's Avatar
glogan
would changing the test pipes clear it up? If so which ones should I get?
Old Jun 14, 2005 | 10:02 AM
GQ 350z's Avatar
GQ 350z
If you get HFC, the sound will be less raspy (if any at all) depending on which ones you go with. I recommend Helix DNA Hi Flows, Crawfords, and the Ultimate Racing Cats.
Ravi
Old Jun 14, 2005 | 11:51 AM
froggy's Avatar
froggy
Before installing Kinetix plenum, I had rasp with Crawford HFC. More air coming through might have solved the anwanted sound...
Old Jun 14, 2005 | 09:00 PM
g356gear's Avatar
g356gear
I have had Mines, Xerd, and Labree resonated......and they all had rasp. None of them had flanges that match up to a stock y-pipe. The stock y-pipe flange actually has a bit of an angle to it.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
