JWT Popcharger & 5AT
Old Jun 14, 2005 | 08:02 AM
pgh2atl's Avatar
pgh2atl
Default JWT Popcharger & 5AT
Hey guys,
Not sure if this is in the right forum for this, but I've been reading about how some people have been having stalling problems with the install of the JWT Popcharger. I have a 5AT & I was thinking of putting a Popcharger in. Is the stalling issue just happen with MT or is this a universal (MT & 5AT) issue? Last thing I want to do is get the Popchager & then start having the car stall on me.
Thanks in advance for the replies!
Old Jun 14, 2005 | 08:11 AM
Fletch69z's Avatar
Fletch69z
Originally Posted by pgh2atl
Hey guys,
I have a 6 MT 350 and the only time I've experienced this is after accelerating the car hard and then putting it into neutral. When the RPM's drop quickly the computer thinks something is wrong and my car has never actually stalled, but the gauges stopped reading and it cut off the accelerator pedal. That's just my experience so I don't really know about the auto. Hopefully not though since it shouldn't ever go into neutral. I've stopped taking mine out of gear and haven't had any more problems.
Old Jun 14, 2005 | 08:24 AM
bio911's Avatar
bio911
The JWT in the automatic will not stall because you are always in gear.. the only time it will stall is if you put it in neutral and you are at high speeds 90+... You will love the JWT popcharger... I painted the heat shield with high temperature paint that contains ceramic material so that it will cut the heat down around the air filter. I would also recomend Motordyne Spacer.. i have the 1/4 inch spacer and you can tell a really big difference.
Old Jun 14, 2005 | 08:31 AM
ANXIOUZ's Avatar
ANXIOUZ
Just don't shift into neutral at high speeds after accelerating hard and you'll be fine.
Old Jun 14, 2005 | 08:32 AM
Fletch69z's Avatar
Fletch69z
That's awesome! You notice a big difference? In sound or in performance or both? I have the JWT popcharger and have a 3/8th's inch motordyne spacer on the way. Can't wait!
Old Jun 14, 2005 | 08:40 AM
The Liu Man's Avatar
The Liu Man
I have an 5AT with the JWT Popcharger... works great. I still love the sound! (Although some would say it sounds like bad brakes but I disagree). Performance wise, this has been beaten to death.. but I love the sound.
Old Jun 14, 2005 | 09:05 AM
pgh2atl's Avatar
pgh2atl
Cool. Thanks guys for the responses. I'm going to order one tonight.
Excuse my ingorance, but what is a motordyne spacer? Where can I get one????
Old Jun 14, 2005 | 09:32 AM
pgh2atl's Avatar
pgh2atl
Also, do I NEED this chrome Z intake tube? Looks to be mainly cosmetic, but if I'm wrong let me know.
I did some research & the spacer sounds like a good idea. Thinking about the 1/4". Any big difference performance-wise between the 1/4" & the 1/2"????
Old Jun 14, 2005 | 09:33 AM
iheartZ's Avatar
iheartZ
is the Jtw POpcharger installation difficult? where can i get some info on the installation?
Old Jun 14, 2005 | 09:39 AM
hbenet's Avatar
hbenet
Does this affect the NISMO Cold air intake?
Old Jun 14, 2005 | 10:12 AM
Fletch69z's Avatar
Fletch69z
It's a piece of cake. Took me like a half an hour. And it comes with directions and pictures which makes it really easy.
Old Jun 14, 2005 | 10:56 AM
rjr204's Avatar
rjr204
I hope this doesn't sound too stupid, but i'm new to the forum. I've been trying to search through old posts...but have had no luck yet. What is a popcharger, and what kind of gains can be expected from it?
Old Jun 14, 2005 | 11:04 AM
RNL323's Avatar
RNL323
Mod My Ride
Do it!
Popcharger is awesome--sound and performance are worth it and install is 30-45 minutes tops. You don't need the intake tube...That's mainly for appearance. I've never stalled either and I've had it for over a year now.
I will be installing my 1/4 MD spacer in the next week or when I get a chance... From what I've read, the combo of the Popcharger and MD Spacer is the best bang for the buck intake mods you can make.
You won't be disappointed.
Old Jun 14, 2005 | 11:33 AM
Lerxst's Avatar
Lerxst
A popcharger is JWT's short ram air intake. You gain a nicer looking engine bay, a very cool sound, and MAYBE a couple of HP at the wheels...
I haven't heard of any problems with the NISMO CAI. I noticed my RPMs dropped a little at idle and it runs a little bit rough (normal for the VQ), but am installing a grounding kit which should fix that problem.
Old Jun 14, 2005 | 12:03 PM
BOZ23's Avatar
BOZ23
yeah, what does a motordyne spacer do?
Old Jun 14, 2005 | 12:17 PM
pgh2atl's Avatar
pgh2atl
Will I need to buy the oil for the popcharger now or does it come pre-oiled???
Plus I was thinking of doing the grounding kit as well, but will this increase performance? I've seen post saying it has no effect whatsoever.........
Old Jun 14, 2005 | 12:25 PM
Netko350Z's Avatar
Netko350Z
One of the reasons that the stalling could be an issue is if the JWT is "over-oiled" and starts to screw with the air flow sensor. I would recomend that when you get the JWT place it on some newspaper and let any excess oil (if any at all) drip.
Sit it there for 1-2 days.
Old Jun 14, 2005 | 01:00 PM
Lerxst's Avatar
Lerxst
It comes pre-oiled... I'm pretty sure you can use K&N oil too... same stuff, different dye color.
As for the grounding kit, some people say yes, others say no. I read one interesting thread where a guy disconnected it, did the dyno, then connected it and did another dyno right away. I think he got about a 3% gain. This can be attributed to warmer tires, etc... but other guys who did two pulls in a row only got about 1.5% gain on the second pull with no changes to the car. Either way, it should smooth out the motor... and for a 6-wire system from Z-Xtreme for $65 USD shipped, I'm not risking much.
Old Jun 14, 2005 | 01:15 PM
FrankieZZ's Avatar
FrankieZZ
Keep the stock intake tube on the popcharger - proven much better than any of the cosmetic attempts !
Old Jun 14, 2005 | 04:57 PM
bio911's Avatar
bio911
http://motordyneengineering.com/PlenumTheory.asp check out that site...
juang20
Intake
Sep 7, 2015 05:37 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
