Kinetix SSV Install Pics
Old Jul 26, 2017 | 11:37 PM
DarkZ03's Avatar
DarkZ03
Dude you should always use a torque wrench on engine compnents
Old Jul 27, 2017 | 07:17 AM
amr_electron's Avatar
amr_electron
Correct, But the instructions didn't mention any torque values
Old Jul 27, 2017 | 07:16 PM
DarkZ03's Avatar
DarkZ03
Don't quote me on it but I think it's like 80-100 inch pounds east to find on the FSM.
Old Jul 28, 2017 | 04:58 AM
amr_electron
That's what happened last time I used a torque wrench on the intake manifold bolts !
Old Jul 28, 2017 | 07:40 AM
rancor's Avatar
rancor
Did you use ft lbs instead of in lbs and can your torque wrench accurately go low enough?
Old Jul 28, 2017 | 09:48 AM
amr_electron
The wrench was set to 110 in.lb as mentioned in the FSM
Old Jul 28, 2017 | 10:54 AM
DarkZ03's Avatar
DarkZ03
There is no way 110 in/lbs is gonna do that to those bolts unless they are stretched to begin with. I wrench for a living and never have seen that lol.
Old Jul 28, 2017 | 02:34 PM
MacJames350z's Avatar
MacJames350z
poop
Old Jul 29, 2017 | 08:20 AM
amr_electron
I double checked the torque settings when the first bolt snapped and it was spot on, Tried the second one & the same thing happened, Then I said f... it and proceeded to tighten the rest and they snapped also.
When I checked the one bolt that didn't snap, It was clear that the bolt has a weak/thin point that for sure would snap if I attempt to use the same bolt again.
Old Jul 30, 2017 | 12:20 PM
DarkZ03's Avatar
DarkZ03
Wow, maybe someone over torqued them prior causing them to stretch?
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
