free mods?
Old Sep 10, 2005 | 09:01 AM
cracka350z's Avatar
cracka350z
Default free mods?
are there any? im a broke *** for the time being and i want better sound/performance....
Old Sep 10, 2005 | 03:17 PM
Smile
Free modifications for performance?
1. Increase tire pressure by a couple of PSI. Decreases rolling resistance.
2. Wash the engine. Accumulated oil and dirt inhibit heat dissipation.
3. Drive with the windows up reducing drag coefficient.
4. Find a deserted parking lot. Set up some cones. Practice.
5. Clean and oil the intake air filter.
6. Never carry more that a quarter tank of fuel.
Old Sep 10, 2005 | 03:35 PM
Chad68's Avatar
Chad68
Toss the rear wiper and spray nozzel and plug the holes, unless you use the rear wiper? Looks way cleaner
Steal an antenna off a S-2000
Old Sep 10, 2005 | 04:34 PM
DavesZ#3's Avatar
DavesZ#3
7. Lighten your Z by removing non-essentials.
Old Sep 10, 2005 | 06:06 PM
sigsauer87's Avatar
sigsauer87
8. Pull the break fuse mod.
Old Sep 11, 2005 | 07:36 AM
I turned ON the rear wiper once in 31,000 miles just to see what it does. Never turned it ON again.
Old Sep 11, 2005 | 01:13 PM
MY350Z.COM's Avatar
IS300 fits better at the base, don't see why everyone always recommends the S2000 antenna which doesn't flow at the base.
Old Sep 11, 2005 | 02:01 PM
Chad68's Avatar
Chad68
I actually got one that goes to a Acura SUV and test fitted it on a Z. It is a tiny bit wider at the base (unnoticable) but looks very similar to the S-2000.
I like the looks of the Pergin (sp is wrong I'm sure) a lot but I have heard that it sucks on reception. And $30 plus shipping for a little stubby 4-5" antenna seems crazy to me.
Old Sep 11, 2005 | 02:16 PM
dainbramage91's Avatar
dainbramage91
you can gut the cats
modify the stock intake box (dont think it does anything but sound different)
remove the rear section of the exhaust (once again dont know if it helps at all.... it'll save weight)
remove the spare and the rear carpet for weight
cut the springs if you want to get reeeeeally ghetto
Old Sep 11, 2005 | 03:14 PM
350Zenophile's Avatar
350Zenophile
Reduce clutch pedal height.
Old Sep 11, 2005 | 04:16 PM
mikedZ33's Avatar
mikedZ33
Pop out the plastic peice behind the front grill on driver side. This opens up the grill where the stock air intake is, allowing more air flow.
Old Sep 19, 2005 | 05:43 PM
trefittyZ's Avatar
trefittyZ
lol, i just posted in a forum created just after this one about a cheap exhaust mod. if u look at the exhaust pipe going out of the muffler towards the front of the car, u will see a big flange, this has two bolts that hold the midpipe and muffler pipe together. unbolt the nuts, and seperate the pipes, now place several washers(rings) on the bolts, and bolt up[ the pipes. now there will be a space between the pipes, letting exhaust sound waves out. make sure you bolt the grounding wire back on though(youll see it when u unbolt the flanges). This mod will most likely give u no power, if not take some, but, its a cheap way to enjoy the Z's melody until u can afford a real exhaust system. Definately a Gehhto rig though. Then again, if money is an issue,,
Old Sep 19, 2005 | 06:30 PM
plumpzz's Avatar
plumpzz
OOHH!! debadge!
and if money really is a problem..'borrow' some from some old lady not watching her purse...
Stevo Z
Oct 3, 2015 09:14 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
