All about Plenum Mods
Old Nov 8, 2005 | 07:46 PM
HockeyZ39's Avatar
HockeyZ39
So is the sport z mag website the only place to order the mag from? Do any stores sell them so I can just go pick one up?
Old Nov 9, 2005 | 02:51 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Are plenum spacers good enough for f/i applications?
Old Nov 9, 2005 | 05:25 AM
zland's Avatar
zland
Sport Z Magazine
I believe they are sold at selected Barnes & Noble's.
Old Nov 9, 2005 | 06:26 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes.
Both Motordyne's and AAM's is made of fairly thick 6061-T6 aluminum alloy. In fact, the 6061-T6 alloy is quite a bit harder and stronger than the alloys used in the plenum castings.
Boost is a non issue to an all aluminum spacer... Pressure wouldn't even be a challenge untill about 200+ PSI. But there probably won't be many Z's running boost that high.
Old Nov 9, 2005 | 08:04 AM
amsweigart@hotm's Avatar
amsweigart@hotm
Excuse my newbines please...What is a plenum spacer and what does it do? Where is it located exactly?
Old Nov 9, 2005 | 08:23 AM
HockeyZ39's Avatar
HockeyZ39
It does what its name says, It spaces your Plenum to create more volume and give more power. The Z has a angled plenum to clear the strut bar (slopes down from back to front) so the front doesnt get as much air as the rest.
Also the plenum is the part that your intake connects to.
I am sure you will get much more technical answers from others but this is my short version!
drifter23's Avatar
drifter23
Go to this website: www.motordyneEngineering.com for motordynes spacer specs and info.
Old Nov 9, 2005 | 08:24 AM
HockeyZ39's Avatar
HockeyZ39
Or that!
Old Nov 9, 2005 | 08:45 AM
amsweigart@hotm
Thank You dudes!
Old Nov 10, 2005 | 09:46 AM
JamMasterW's Avatar
JamMasterW
does anyone have the skunk2 plenum spacer?
ok, im interested in the
-motordyne plenum spacer 5/16 in which a cusco bar can be used (will the greddy strut bar clear it also????)
-skunk2 spacer...http://www.skunk2.com/Merchant2/merc...roduct_Count=0...
BUT will the stock, cusco or greddy bar clear it???
Old Nov 10, 2005 | 10:30 AM
THE TECH's Avatar
THE TECH
I'm interested in knowing which ones work with the stock strut bar AND retain the use of the factory engine cover.
Old Nov 10, 2005 | 04:03 PM
RNL323's Avatar
RNL323
Mod My Ride
Motordyne 5/16 and 1/2 will work with the engine cover, however the 1/2, I believe will not work with the strut bar.
Not sure of the skunk2 or the AAM.
I would recommed the the Motordyne Iso Thermal... Not only because I have it intalled on my Z and enjoy my gains, but also because Tony (Hydrazine) of Motordyne eng. is always around to answer your posts or PM's...
Old Nov 15, 2005 | 01:58 PM
HockeyZ39's Avatar
HockeyZ39
So is the issue with the plenum shoot out on stands yet?
If not when should I expect it?
Old Nov 15, 2005 | 02:54 PM
Diesel350's Avatar
Diesel350
Should be out by Dec 1st.
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
