Kinetix, crawford, or aps plenum?
Old Nov 3, 2005 | 05:44 PM
1sick350's Avatar
1sick350
Default Kinetix, crawford, or aps plenum?
FIrst off is it worth it for the intake plenum, and is there a noticeable difference. I heard that the crawford cant be used witht he stock strut bar and there is something about the original engine cover not fitting. Which is the best?
Old Nov 3, 2005 | 08:00 PM
Florida350zrt's Avatar
Florida350zrt
Default Plenum vs.Spacer
I would go with a Plenum spacer...
You don't have to change your strut bar and it is much cheeper then an upper plenum...
The next up the line is the Kinetix Version-4 composit upper plenum replacement...
Then you have Craford which on all models you have to change the strut bar and trim your engine cover to fit... But their all excellent and they all do the same thing, allow more air to the front cylinders. There is an extra cost to replace the strut bar but you could trim the engine cover yourself.
Now the daddy of them all: KINETIX SSV total replacement plenum. An excellent choise that lightens your wallet nearly a k...
I'm sure there is more to come.
Skunk even makes a plastic composit spacer that clears the strut bar... It's all good in my opinion as long as she's getting more air... What ever your budget allows...
If cost is no object, then the SSV is your baby
If you want to mod. out your car NA to the max the SSV would be good with a reflash but to maximize its benifits you would be better off going
FORCED INDUCTION.
PS: Sorry to forget the APS... It does the same thing as the rest
Old Nov 3, 2005 | 09:02 PM
Mike Wazowski's Avatar
Mike Wazowski
1 word
CRAWFORD
Old Nov 5, 2005 | 11:10 AM
1sick350's Avatar
1sick350
thanks for advice
Old Nov 5, 2005 | 12:10 PM
screener's Avatar
screener
Are you sure about this,it's a non angled 5/8 inch spacer and i thought the strut bar went the cover needed cut and the hood raised. .I noticed when they tested it in the Dec. 05 import tuner they had the hood off mmmm.
2nd word
Crawford ( still on my wish list though )
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
