APS plenum
Old Nov 19, 2005 | 11:31 AM
esfand's Avatar
esfand
Cool APS plenum
wat up guys i'm about to buy the APS plenum and was wondering if anyof you out there have it and what are ur thoughts about it. i know the install is easy, but what i want to know is if anyone did a b4 and after dyno or at least felt a befrore and after improvement. also what did you do about the strut bar situation??
Old Nov 19, 2005 | 03:22 PM
ChromiumBlue's Avatar
ChromiumBlue
it should be satisfying
There are 212 “APS plenum” posts. Please read them. Thanks.
Old Nov 20, 2005 | 09:23 PM
esfand's Avatar
esfand
actually sir, there are 153 matches when you search for aps plenum, but none of them answer my question, has anyone tried to use the factory bar by making spacers. but thanks for ur help though.
Old Nov 20, 2005 | 09:38 PM
HoldThisForMe's Avatar
HoldThisForMe
I am gathering that even if you did shim up the strut bar to clear the plenum it would still hit your hood...i could be wrong but i think im on the right track tho.
Old Nov 21, 2005 | 09:04 AM
TK2005's Avatar
TK2005
Why would you get the APS plenum? Do you have a complete APS setup and you want get a theme going? Do you have a brand loyalty? Is APS sponsoring you? You know that spacers do the exact same thing for about a third to half of the price right? Obviously it is your car and you can do what you want but you should know they are the same thing with the same returns. I personally like APS products and I may eventually get the APS plenum as well but only so it goes along with the APS TT setup, the APS cat-delete pipes, and the APS exhaust.
Old Nov 21, 2005 | 10:33 AM
esfand's Avatar
esfand
got the cat-delete pipes and are workin on the rest
Old Nov 22, 2005 | 09:38 AM
dirtroad's Avatar
dirtroad
uhh.. i like my APS plenum, although it went on the same time as my turbo so it's hard to say... there is more of a growl than the stock one, i'd say. get it. especially if you're planning on going FI in the future.
Old Nov 22, 2005 | 07:40 PM
Default Well since you did search...
the APS upper plenum negates the OEM strut brace. You can toss the black plastic engine cover, and get a “straight” strut brace. I believe that the following will work:
GT SPEC &185
Cusco $165
Stillen $147
JIC $170
Greddy Strut Tower Bar $104
Crawford $150
allmycarsdie
May 13, 2016 04:38 PM
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
