POP Charger/Warranty
I installed a JWT pop charger aboujt 6 months ago. Now that the air is colder, I have rough idling (around 600 rpm). Before I take it to the dealer, should I swith back to the origianal intake? Also, is the cold air a big factor in the rough idling?
check for airleaks.. or loose maf connector. its most likely an airleak. Also, clean ur filter if u havn't. I doubt it has anything to do w/ the popcharger construction. If it all fails. put on the stock airbox
If you installed the pop charger 6 months ago, and are having problems now, I doubt if it has anything to do with the pop charger. I’ve been taking evening cruises with the temperature below 32 degrees, and the 350Z loves freezing air. BTW I doubt if any adjustments are covered under warranty.
NOLAGG
Misc.
09-28-2015 04:14 PM
B Esquire
09-24-2015 07:52 AM
