Where to find a 72mm Throttle body?
Old Dec 16, 2005 | 01:17 PM
ARLETOS 350Z's Avatar
ARLETOS 350Z
Have any pics of this one?propably not a vq45 but a vh45??
Old Dec 16, 2005 | 01:28 PM
thawk408's Avatar
thawk408
Originally Posted by Zivman
Just keep in mind:
The dyno that I go to in consistent. I do understand that there is sometimes error, but I have never seen any on this dyno. It is dynojet and not a load based dyno.
Old Dec 16, 2005 | 01:29 PM
seanlaw's Avatar
seanlaw
sorry a vk45 ... the engine in the Q45
Old Dec 16, 2005 | 01:40 PM
Zivman's Avatar
Zivman
You can easily see up to a 5 hp swing on ANY dyno between runs. This swing is much larger than any gains a bored throttle body will give.
I have ran many cars on dynojets and never got the same exact numbers on each run.
Old Dec 16, 2005 | 01:56 PM
drsifu's Avatar
drsifu
agree to disagree
i agree that each dyno run will be different due to variances in testing parameters. if you get back to back runs within 1-2 HP, consider it a lucky coincidence.
best of luck
Old Dec 16, 2005 | 02:02 PM
Zivman's Avatar
Zivman
Originally Posted by drsifu
agree to disagree
best of luck
If you saw a 1-2 hp variance, how would determine if a gain was made?
I am interested in seeing the dynos. I had already bored my throttle body and replaced it due to TPS codes. I didn't feel much of any gain before it began giving me issue. I had a bored TB on another car of mine and it gave nice throttle response, more than I felt with the same modfication on the Z.
Old Dec 16, 2005 | 04:36 PM
thawk408's Avatar
thawk408
I will just do it, then post the numbers up and you can give me your opinion. I would think that any increase in air you can give this engine would help out. Does anyone know if the q45 throttle body bolts up to our motor? I am sure you would need to make the inlet to the plenum bigger, but this shouldnt be to hard.
Old Dec 16, 2005 | 07:40 PM
LOU's Avatar
LOU
I believe the Q45 TB was welded to the plenum on that car. So I am guessing that it doesn't bolt up.
Old Dec 17, 2005 | 02:09 PM
atlsupdawg#2's Avatar
atlsupdawg#2
Originally Posted by atlsupdawg#2
What size is the stock throttle body..??
HUH?????
Old Dec 19, 2005 | 07:32 PM
Nismo 350z's Avatar
Nismo 350z
HUH?????
He asked how big is the stock throttle body is. I believe its 70mm... not sure though.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
