Where to find a 72mm Throttle body?
Old Dec 15, 2005 | 12:20 PM
350Z007's Avatar
350Z007
Default Where to find a 72mm Throttle body?
Does anyone know where you can buy these for the Z or if anyone even makes these?
Old Dec 15, 2005 | 01:38 PM
Mike Wazowski's Avatar
Mike Wazowski
http://www.proflowdesign.com/throttlebodies.html
Old Dec 15, 2005 | 01:57 PM
atlsupdawg#2's Avatar
atlsupdawg#2
What size is the stock throttle body..??
Old Dec 15, 2005 | 02:46 PM
350Z007's Avatar
350Z007
Originally Posted by USN HM 350Z
Thank you. That's what I was looking for.
Old Dec 15, 2005 | 03:41 PM
bverschage's Avatar
bverschage
CrawfordZ sells one that is 73mm.
Old Dec 15, 2005 | 04:40 PM
meatbag's Avatar
meatbag
Have a link to the crawford?
Old Dec 15, 2005 | 04:42 PM
rico3682's Avatar
rico3682
what kind of power are you looking to gain from this mod? price is reasonable.
-Eric
Will Pwr's Avatar
Will Pwr
www.crawfordz.com/
Old Dec 15, 2005 | 04:53 PM
350Z007's Avatar
350Z007
-Eric
From people that I've talked to it will give you a few hp up top and better top end and throttel response. More of a quickness mod than a hp mod.
Old Dec 15, 2005 | 08:09 PM
ZlleH's Avatar
ZlleH
How hard is it to install?
Old Dec 16, 2005 | 03:05 AM
350Z007's Avatar
350Z007
From past experience with other cars it is just unbolt and rebolt on.
Old Dec 16, 2005 | 04:31 AM
Z350Lover's Avatar
Z350Lover
I think the larger throttle will only work well if you bore out the plenum air entry as well... and does anyone know if the larger throttle affects the idle quality? Thanks
cheers,
richie
Old Dec 16, 2005 | 07:16 AM
Zivman's Avatar
Zivman
All bored throttle bodies are the same. there is only so much you can bore out of them before the walls become too thin. the proflow, 350evo, and crawford are all the same. The gains don't come from the bore itself. they come from a modified throttle plate and shaft. The shaft is basically cut in half.
I wouldn't recommend a bored throttle body. The Z's throttle body is drive by wire and the TPS (throttle position sensor) is VERY sensitive. This makes boring out the throttle body a real gamble. the TPS becomes very finicky with the larger parameters it now sees. You will most likely throw continuous CEL lights with your car going into limp mode. You cannot replace the TPS on the throttlebody, you must replace that entire unit at tune of 600-800 bucks. I am speaking from experience.
If you run the crawford plenum, the inlet that the TB bolts to at least .5" larger than the OEM plenum opening. More than accomodating bored throttlebodies.
It does not affect idle quality
Old Dec 16, 2005 | 10:53 AM
thawk408's Avatar
thawk408
I know people running the Crawford with no issues.
Old Dec 16, 2005 | 10:55 AM
Zivman's Avatar
Zivman
Great thanks for the input.
you will always have people that will run without issues and some that have issues. My point is, for the miniscule gains you get from this, it isn't worth the headache.
Old Dec 16, 2005 | 11:43 AM
thawk408's Avatar
thawk408
It might be miniscule, but gains are gains. I will probably get one eventually just to see what numbers I can get.
Old Dec 16, 2005 | 11:59 AM
Zivman's Avatar
Zivman
The gains will be so minuscule that you won't be able to measure them on a dyno. Variances between runs are greater than any gains a bored throttlebody will give.
Old Dec 16, 2005 | 12:01 PM
thawk408's Avatar
thawk408
We will just have to see. I will be getting one soon and I will be doing a dyno before and after. I will be swapping the throttle body while on the dyno also.
Old Dec 16, 2005 | 01:07 PM
Zivman's Avatar
Zivman
Just keep in mind:
Old Dec 16, 2005 | 01:11 PM
seanlaw's Avatar
seanlaw
you could always go with a modified VQ45 throttle body...not sure of the electronics and mounting points but if i remember someone did it...i think it's 90mm
