question
Old Dec 20, 2005 | 10:42 PM
LODOSS's Avatar
LODOSS
Default question
getting info making sure i install the plenum correctly.. when i unplug the power to the bat will it reset the info on my radio? does that mean i'll have to reprogram my stock radio and also is there like a security code for it? if so where is it located? thanks
Old Dec 20, 2005 | 11:21 PM
Tortuga's Avatar
Tortuga
After installing my plenum I had to reprogram the radio. I don't think there is any code, I didn't use one. Should not be a problem.
Old Dec 21, 2005 | 01:45 AM
MarquisDeSam's Avatar
MarquisDeSam
any time you pull the neg. terminal out of the battery, your radio presets needs to be reset.
Old Dec 21, 2005 | 01:48 AM
overZealous1's Avatar
overZealous1
selling the car will be the best option at this point!!
you will have the task of programming your radio again. lets just hope this is the only prob you run into. and if this is a prob, don't change your own manifold! hahaha
Old Dec 21, 2005 | 06:00 AM
The dash lighting will also return to default. Is it worth replacing the upper plenum. Think it over.
Old Dec 21, 2005 | 06:03 AM
LODOSS's Avatar
LODOSS
Lol you bums... so when you guys said reprogram.. you just mean setting up the clock and stations blah..... thats not reporgramming =p make it sound all technical.
What I was afraid of.. was like my old acura.. where the battery died and i had to go to the acura dealer to get the code in order to turn the CD player back on..
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
