What is the thickest plenum spacer out there?
Old Jan 5, 2006 | 03:17 PM
oorx7's Avatar
oorx7
Vendor - Former Vendor
Question What is the thickest plenum spacer out there?
I am wondering what the thickest spacer there is out there. I am not concened with retaining the strut tower bar. I am mostly concerned with the stock hood clearence.
From what I can gather, there are 5/16" and maybe a 1/2". There are also some angled spacers wich I would need a demensions for the front and rear.
I am interested more in the size, than brand. If you guys (gals) could give me some demensions, even including thermal gaskets that would be great.
Thanks
Brandon
Old Jan 5, 2006 | 03:25 PM
DavesZ#3's Avatar
DavesZ#3
Motordyne offers both a 5/16" and 1/2" spacer.
http://www.motordyneengineering.com/350Z.asp
Altered Atmosphere has a 1/2" tapered (down to 1/4" at rear).
http://www.alteredatmosphere.com/350z_1.asp
The Isothermal Gasket will add about another 1/16" in overall height to the plenums.
Old Jan 5, 2006 | 03:38 PM
oorx7's Avatar
oorx7
Thanks for the quick response.
So do you think that the 1/2"spacer plus 1/16"gasket is the largest out there.
I am looking at gaining the most volume, because I think this will be best for my aplication.
Old Jan 5, 2006 | 04:41 PM
showstoppertk's Avatar
showstoppertk
the 1/2" is the largest I've heard of, however you'll have to get a new strut bar, you won't be able to reuse the engine cover and you'll need to either get hood spacers or a new hood.
Old Jan 5, 2006 | 06:40 PM
DaveO's Avatar
DaveO
Thanks
Brandon
Skunk2 Racing's 5/8" spacer is the thickest we're aware of. Bigger & thicker is not always better. You might check out the Shootout in the latest issue of Sport Z Magazine.
DaveO
G35 Editor
Sport Z Magazine
Old Jan 5, 2006 | 06:45 PM
Mike Wazowski's Avatar
Mike Wazowski
I used the AAM 1/2 spacer and my strut bar worked as did my engine cover and hood so I have no idea where you got your information.
DavesZ#3's Avatar
DavesZ#3
DaveO
G35 Editor
Sport Z Magazine
How true - Tony from Motordyne freely admits that the amount of gain when going from 5/16" to 1/2" is mimimal.
Old Jan 5, 2006 | 07:42 PM
+1. The difference between 1/2 and 5/8 inches is only 3/8 inch, but the effects on both the horsepower and torque curves are revealing. Thanks to your plenum shoot out.
Old Jan 6, 2006 | 03:21 AM
oorx7's Avatar
oorx7
Not to bust your ***** buddy but 1/2" =4/8" wich would mean 5/8" is only 1/8" difference.
Please lets not turn this into a debate on wich is better or not. This is not really what I am looking for.
Thanks for the imput guys it is much appreciated. In the next couple of months you guys will see why I whanted this info
Old Jan 6, 2006 | 03:24 AM
oorx7's Avatar
oorx7
DaveO
G35 Editor
Sport Z Magazine
Did this clear the hood ok? I thought Skunk made a spacer.
Not to shure on were I can get that mag, I have only heard about it on here.
Thanks again
Brandon
Old Jan 6, 2006 | 06:32 AM
I made a typo. Correction:
The difference between ½ and 5/16 inches is 3/16 inches.
Old Jan 6, 2006 | 06:39 AM
Always interested in members using mods in unique ways. Keep us posted.
Old Jan 6, 2006 | 06:42 AM
oorx7's Avatar
oorx7
Ha Ha, no problem. I am shure I will be making my fair share of typos in the future.
I will keep everyone posted, don't worry.
Old Jan 6, 2006 | 03:10 PM
showstoppertk
my bad, I should have been more specific. the AAM spacer is an angled spacer if I'm not mistaken, which is the reason that it allows for the the stock strut bar (w/added washers) and cover to be used. I don't know of any 1/2" non-angled spacer that allows for the stock strut bar and cover to be used.
Old Jan 6, 2006 | 05:48 PM
DaveO's Avatar
DaveO
Thanks
Brandon
Brandon,
I covered the 350Z Strut Bar fitment issue in the Plenum - Spacer Shootout. A hint... 1/2" and above won't allow use of the stock bar.
You can get an issue on line -- http://www.sportzmagazine.com/Z_Order.htm
No more hints.
DaveO
Old Jan 7, 2006 | 03:20 AM
Fairlady_z33's Avatar
Fairlady_z33
Guys i have a greddy TT which will give better gains from motordyne the 1/2 or 5/16. And will i be able to use my stock tower bar. Thanks
Old Jan 7, 2006 | 12:44 PM
showstoppertk
I don't think anyone has done tests on that yet, but based on the current info I'd say the 1/2 would give you higher gains. but no, you won't be able to use the stock strut bar w/ the motordyne 1/2 spacer. however USN HM 350z said he was able to use the 1/2 AAM spacer w/ the stock strut bar so perhaps that will work. however I would suggest going w/motordyne based on my experience.
Old Jan 9, 2006 | 01:15 PM
rbfd's Avatar
rbfd
I have the Motordyne 1/2 inch Iso-Thermal spacer and am using a stock strut bar. The install was done by 350Evo, BJ said all he did to use it was put on some washers and it fit.
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
