Track Lower Plenum+5/16" MD Spacer?
Old Jan 20, 2006 | 01:42 AM
  #41
reptile718's Avatar
reptile718
um I really would not recommend that, on second thought that would prob. be one of the worst things you can do. lets say for some crazy reason you could get it to run 1. There would be no intake to filter our any harmful debri comming into your engine. 2. You would be sucking in large amounts of hot air comming from your engine so a major decrease in power. 3. How would you even control your throttle without a throttle body unless you run it wide open in which case I can see one of two things A. BOOM! or B. Major PING and your Z's brain would kick you into safe mode which is no fun. Best thing for you would be to buy a lower intake plenum from a pre 06 somewhere else, you can find oue cheaper then motordyne then just simply buy their 5/16 spacer with all the isothermal goodies, this will yield the highest gains for the revup engine.
Old Jan 20, 2006 | 04:07 AM
  #42
Netko350Z's Avatar
Netko350Z
Quick question on MD install....
Do you really need to buy a 2nd plemun gasket?
